beataru Posted September 19, 2006 Share Posted September 19, 2006 Hey anyone know where i can get poly bushings for my car.. i bought it from rallyruss and it has everything except the swaybar bushings done to it and also i would like to replace the shift bushings... its getting annoying how loose it is! i am willing to get stock bushing from 1stsubaruparts.net i think it is but polys would surely feel stiffer Link to comment Share on other sites More sharing options...
daeron Posted September 19, 2006 Share Posted September 19, 2006 i just hacked my way thru the net and found that, for the price on the full-car kit for my Zcar, summit racing equipment was cheaper than anyone else.. it was odd, all the other companies had the same price.. about 175.. and summit had it for 150 and change.. its like their markup was lower. thats why i thought i would mention it. i dont have the URL handy, google it. Link to comment Share on other sites More sharing options...
beataru Posted September 19, 2006 Author Share Posted September 19, 2006 Why would poly bushings be more expensive... if anything they should be cheaper.. your putting plastic where rubber should go! Link to comment Share on other sites More sharing options...
daeron Posted September 19, 2006 Share Posted September 19, 2006 well, "rubber" hasnt necessarily meant natural rubber latex since WWII... so its not necessarily cheaper than rubber. secondly, wait till you get to take an economics class again, not being a jerk, im just saying that, the simple fact that it is a "performance part" guarantees that itll be more expensive than stock simply because. its a demand thing, if they charged less they would sell more units, but in the end not make as much money. once you take the economics class, it WILL make sense i promise you.. its the unfair-seeming side of capitalism, unfortunately. Link to comment Share on other sites More sharing options...
beataru Posted September 20, 2006 Author Share Posted September 20, 2006 Ive heard that poly bushings arnt always noted as a performance part.. just a cheap replacement Link to comment Share on other sites More sharing options...
daeron Posted September 20, 2006 Share Posted September 20, 2006 they are stiffer than typical compounds used for suspension bushings. this conducts more vibration and road feel through the suspension and into the car, and allows for more precise handling. there may be instances where replacing with poly bishings is cheaper than stock/oem bushings, i dont doubt.. but its not a "cheap alternative" so to speak, you know? i honestly couldnt tell you how much stock bushings might run, ive never looked into it Link to comment Share on other sites More sharing options...
rallyruss Posted September 20, 2006 Share Posted September 20, 2006 the ones on the car are made by superpro if I rember correct. I belive they came from down under (AU). WJM was in the business of distributing some at one point. He may know where to find more. they were reasonably priced in conparison to stock bushings at the time. you may just want to get the factory ones. they are probably simpler to find. as for the shift bushings the oem ones are the only option that I know of. good luck. glad it has a happy new home. ah yes.. poly bushings are usually considered a performance upgrade as they handle better and last longer than most factory parts when made properly. they do tend to make the ride a little bit harsher though for those who care. Link to comment Share on other sites More sharing options...
rallyruss Posted September 20, 2006 Share Posted September 20, 2006 http://www.superpro.com.au/home.html you will need to measure the sway bar to get the corect ones. shipping might hurt too unless you find a local source. Link to comment Share on other sites More sharing options...
beataru Posted September 21, 2006 Author Share Posted September 21, 2006 allright thx russ... the parts were not in 1st subarus inventory but they should get them tomarrow and then shipem out to mee.... :-\ i was hoping id get the roo back on the road this weekend... ohwell Link to comment Share on other sites More sharing options...
Moodybluesr Posted September 22, 2006 Share Posted September 22, 2006 I put ES poly bushings on the front sway bar of my XT6 a couple of months ago, and they made a hell of a difference! All the sudden my rear end swings out in the hairpins. I did a write-up of what was involved, including part numbers, on xt6.net. You would probably have to order different bushins, though, if your bar isn't 20mm. Link to comment Share on other sites More sharing options...
