simbey1982 Posted September 22, 2006 Share Posted September 22, 2006 Hey all, i have a 1992 Legacy turbo (1st gen legacy). Im having major issues with a sticky Starter interlock relay. So i need to replace it. Trouble is i dont want to tear the dash apart just looking for it. Where would i find this relay?? Link to comment Share on other sites More sharing options...
nipper Posted September 22, 2006 Share Posted September 22, 2006 simbey1982 said: Hey all, i have a 1992 Legacy turbo (1st gen legacy). Im having major issues with a sticky Starter interlock relay. So i need to replace it. Trouble is i dont want to tear the dash apart just looking for it. Where would i find this relay?? right next to the brake pedal nipper Link to comment Share on other sites More sharing options...
simbey1982 Posted September 22, 2006 Author Share Posted September 22, 2006 hmm...ill have to check that out..i followed the wire from the ignition switch and it went up into the bulkhead harness....must drop down again. Link to comment Share on other sites More sharing options...
nipper Posted September 22, 2006 Share Posted September 22, 2006 simbey1982 said: hmm...ill have to check that out..i followed the wire from the ignition switch and it went up into the bulkhead harness....must drop down again. haynes manual shows it pretty well as being mounted on the brake pedal box. nipper Link to comment Share on other sites More sharing options...
simbey1982 Posted September 22, 2006 Author Share Posted September 22, 2006 thanks Link to comment Share on other sites More sharing options...
Legacy777 Posted September 23, 2006 Share Posted September 23, 2006 It has a blue connector, and is between the brake & gas pedal area up under the dash. Link to comment Share on other sites More sharing options...
