chadwick2004 Posted September 23, 2006 Share Posted September 23, 2006 I have a unusual issue with my 2004 subaru 35th anniversary edition sedan, I have about 29k on it and have taken it do a dealer in my area pete's subaru here in western mass and have complained about a whistle noise or squeal noise about 40mph, I can get it to do it for me but the tech could not duplicate it of course. They told me it was a normal noise I was hearing from the ac condenser, um no I worked at a dealer and that is not a normal noise coming from the clutches in the ac condenser. So it happens in warm weather and cold weather. I have had the belts adjusted also and checked and they are fine so where is this noise coming from man it annoys me. please help with solutions or suggestions.:-\ Link to comment Share on other sites More sharing options...
OB99W Posted September 23, 2006 Share Posted September 23, 2006 You say the noise occurs at about 40 mph; what happens to the noise if you drive at 40 in various gears? Link to comment Share on other sites More sharing options...
chadwick2004 Posted September 23, 2006 Author Share Posted September 23, 2006 OB99W said: You say the noise occurs at about 40 mph; what happens to the noise if you drive at 40 in various gears? I never tried it but it goes away after after 40 mph and I speed up thats why it is hard to duplicate Link to comment Share on other sites More sharing options...
idosubaru Posted September 23, 2006 Share Posted September 23, 2006 this vehicle doesn't have hubcaps does it? i don't think it does, but if it does i'd try reseating them all. any inclination where it's coming form? front, rear, center, left, right? is it just wind noise, do you have a roof rack? Link to comment Share on other sites More sharing options...
nipper Posted September 23, 2006 Share Posted September 23, 2006 chadwick2004 said: I have a unusual issue with my 2004 subaru 35th anniversary edition sedan, I have about 29k on it and have taken it do a dealer in my area pete's subaru here in western mass and have complained about a whistle noise or squeal noise about 40mph, I can get it to do it for me but the tech could not duplicate it of course. They told me it was a normal noise I was hearing from the ac condenser, um no I worked at a dealer and that is not a normal noise coming from the clutches in the ac condenser. So it happens in warm weather and cold weather. I have had the belts adjusted also and checked and they are fine so where is this noise coming from man it annoys me. please help with solutions or suggestions.:-\ Does the squuel change with road speed or engine speed Of not sure hold the car in gear manually and see. Does it change with the a/c on or off Does it change with electrical laod Does it change with the sindows up or down Does it change when making a turn Is it there when you rev the car in park and neutral nipper Link to comment Share on other sites More sharing options...
chadwick2004 Posted September 23, 2006 Author Share Posted September 23, 2006 grossgary said: this vehicle doesn't have hubcaps does it? i don't think it does, but if it does i'd try reseating them all. any inclination where it's coming form? front, rear, center, left, right? is it just wind noise, do you have a roof rack? it does not have any hubcaps it has alloy wheels the noise is coming from the fron tof the car more like the engine itself or within it. Link to comment Share on other sites More sharing options...
nipper Posted September 23, 2006 Share Posted September 23, 2006 Assuming there are no vaccum leaks, or anyother oddities, the only other thing that can whine are hydraulic pumps. You have two, the PS pump and the front pump in the tranny. Now i am doing worst case and may be way off base since i cant hear the noise. The PS pressure reduces pressure at highway speed. i don't know what they consider highway speed, nor am i quite sure how this done, i would imagine its done in the rack. Since you say it always stops at 40mph, i would look there. The tranny will sound loudest at low speeds if its a bad front pump. I wouild remove the drive belts and see if it goes away. You can drive the car a bit with the belts off. If it goes away, that reduces it to a rotating mass, the AC PS ALT or adjuster/idler pullies. Either way i suggest you take the technician on a drive with you driving, and let them hear it when you hear it. Keep all the documentation on this incase its either scenario so you can prove that you were complaining about this. nipper Link to comment Share on other sites More sharing options...
chadwick2004 Posted September 23, 2006 Author Share Posted September 23, 2006 nipper said: Does the squuel change with road speed or engine speedOf not sure hold the car in gear manually and see. Does it change with the a/c on or off Does it change with electrical laod Does it change with the sindows up or down Does it change when making a turn Is it there when you rev the car in park and neutral nipper Hi thank you for responding well lets see I can hear it when the windows are open and closed does happen at around 40mph and squeals and as I speed up it goes away the noise is coming from the front of the car I suspect the engine somewhere or even the exhaust somewhere. I can not here it if it does it when turning, it seems to happen when I am driving. it does not matter whether the a/c is on or not either. with any electrical equip on does not matter either so its tough to figure out, the dealership had it all day and they claimed they could not hear it, sometimes I go at 40 or so and it will do it and I told them that to. Link to comment Share on other sites More sharing options...
chadwick2004 Posted September 23, 2006 Author Share Posted September 23, 2006 nipper said: Assuming there are no vaccum leaks, or anyother oddities, the only other thing that can whine are hydraulic pumps. You have two, the PS pump and the front pump in the tranny. Now i am doing worst case and may be way off base since i cant hear the noise. The PS pressure reduces pressure at highway speed. i don't know what they consider highway speed, nor am i quite sure how this done, i would imagine its done in the rack. Since you say it always stops at 40mph, i would look there. The tranny will sound loudest at low speeds if its a bad front pump. I wouild remove the drive belts and see if it goes away. You can drive the car a bit with the belts off. If it goes away, that reduces it to a rotating mass, the AC PS ALT or adjuster/idler pullies. Either way i suggest you take the technician on a drive with you driving, and let them hear it when you hear it. Keep all the documentation on this incase its either scenario so you can prove that you were complaining about this. nipper cool well it starts up around 40mph i'm sorry and then goes away as i speed up Link to comment Share on other sites More sharing options...
nipper Posted September 23, 2006 Share Posted September 23, 2006 chadwick2004 said: cool well it starts up around 40mph i'm sorry and then goes away as i speed up hrmph Link to comment Share on other sites More sharing options...
OB99W Posted September 23, 2006 Share Posted September 23, 2006 nipper said: hrmph Indeed. Link to comment Share on other sites More sharing options...
montana105 Posted September 24, 2006 Share Posted September 24, 2006 My 93 makes the same noise but it does it at certain speeds in all gears,a mechanic thought it might be air whistling through the intake or by the butterflies as it instantly disappears if you let off the gas even minutely. Think I'll pull the intake hose off and clean it all up. Just swapped in a complete 92 Ej22, got it running Thursday and it is making the same exact noise. What do you think? John Link to comment Share on other sites More sharing options...
Shayna Posted September 24, 2006 Share Posted September 24, 2006 This happens with my car (whistling in all gears) and i used to worry about it, but when my bf was trying to sell my car, he told the most interested buyer about this, who had owned 2 subarus previously and one currently. He said 2 of his had done this but had caused no tangible problems, and said it was just a subaru quirk. Since this only happens to me when the car is being driven properly (maybe a little hard) i don't worry about it anymore, now thinking of it as a happy sound, whistling past the other cars. And hopefully i won't have to worry about it in the future since i decided against selling. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 24, 2006 Share Posted September 24, 2006 Did this happen after some service was done? Are there ANY other issues with the car that seem unusual? Carl Link to comment Share on other sites More sharing options...
chadwick2004 Posted September 24, 2006 Author Share Posted September 24, 2006 1 Lucky Texan said: Did this happen after some service was done? Are there ANY other issues with the car that seem unusual? Carl Nope I was driving home from work one day and it just started making the noise and I heard it and that was it but no services were done prior. Link to comment Share on other sites More sharing options...
Manarius Posted September 24, 2006 Share Posted September 24, 2006 I wonder if it's belt or pulley squeal. Most likely would be coming from the Alternator if it was either of those. Driving without the belts would be a good idea to check this - but I don't know if you're going to be able to get up to 40 mph safely without electricity from the alternator... Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 24, 2006 Share Posted September 24, 2006 Can you describe the noise with more detail? Also, how's the radio reception - especially AM. Carl Link to comment Share on other sites More sharing options...
nipper Posted September 25, 2006 Share Posted September 25, 2006 I just drove 12 hrs average speed 60 mph, and guess what, my car whistles too. Its not the roof rack, but its more tire and road surface related with cement worse then asphalt. nipper Link to comment Share on other sites More sharing options...
WRX2FFU Posted September 25, 2006 Share Posted September 25, 2006 Is it a mechanical noise or maybe a wind whistle? Link to comment Share on other sites More sharing options...
nipper Posted September 25, 2006 Share Posted September 25, 2006 mine is tire/wind related, worse on cement, dramatically reduced on blacktop, nothing the 80 watt stero cant mask nipper Link to comment Share on other sites More sharing options...
xrturbo Posted September 25, 2006 Share Posted September 25, 2006 you stated in the original post they told you it was the condenser, and then you said about the clutch on the condenser..... is it possible you are missunderstanding what they are telling you? and that maybe the noise is a wind whistle through the condenser? the condenser is the radiator looking thing in front of the radiator. not trying to make you look stupid or anything, but it would clear up confusion.... Link to comment Share on other sites More sharing options...
xrturbo Posted September 25, 2006 Share Posted September 25, 2006 this isnt one of those riddles where noone was really on the train to begin with..... is it?? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 25, 2006 Share Posted September 25, 2006 xrturbo said: this isnt one of those riddles where noone was really on the train to begin with..... is it?? hah! "let's see....angry, hungry -what's the 3rd one ending in gry????" lol! Carl Link to comment Share on other sites More sharing options...
montana105 Posted September 25, 2006 Share Posted September 25, 2006 Mine is definitely throttle related,as soon as the whistle starts I can let off the pedal even the slightest bit without affecting the speed of the car and the sound goes away, same the other way around, if i step on the pedal the sound goes away.Not sure if this is the sound though the original poster described. John Link to comment Share on other sites More sharing options...
nipper Posted September 25, 2006 Share Posted September 25, 2006 montana105 said: Mine is definitely throttle related,as soon as the whistle starts I can let off the pedal even the slightest bit without affecting the speed of the car and the sound goes away, same the other way around, if i step on the pedal the sound goes away.Not sure if this is the sound though the original poster described. John If it is just the air pssing through the throttle there isnt much you can do about it. nipper Link to comment Share on other sites More sharing options...
