RallyKeith Posted September 25, 2006 Share Posted September 25, 2006 So, I decided to ask the group for the inside poop on this. One of the input shaft bearings is getting noisy in my 95 Legacy. With 198K on the clock, and some neglect on my part (and the previous owner) it's no surprise it's got problems. My dad has a trans from his 91 Legacy that I could just swap in, but I think the final drive ratios are different. I think I've got a 4.11 final drive, and the 91's had 3.90 but he seems to think his was 4.11 So boys and girls, tell me the truth... Keith Link to comment Share on other sites More sharing options...
Manarius Posted September 25, 2006 Share Posted September 25, 2006 Any year 1990-2007 will fit, depending on how much work you want to do. If you don't want to replace the rear diff, 95-99 5MT's are 4.11 as I recall - So you'd need a 5MT from a 95-99 Legacy.. From 90-94, they're 3.90. Link to comment Share on other sites More sharing options...
idosubaru Posted September 25, 2006 Share Posted September 25, 2006 if you have a known good trans sitting there, i'd definitely use it. swap in the rear diff to match and you're golden. you can ask the off-road guru's what difference changing from 4.11 to 3.90 would make, but it won't be very much. of course verify and then double check all your diff ratios and make certain they match. Link to comment Share on other sites More sharing options...
subeman90 Posted September 26, 2006 Share Posted September 26, 2006 90-94 legacy 5 speeds were 4.11 and the TURBO 91-94 were 3.90 Trust me on this one.....i have been on this road before. FWIW, If you can find a 3.90 turbo tranny you will give up a little off the line but your mileage will go up greatly (I did this swap and couldn't believe my eyes/calculations) Link to comment Share on other sites More sharing options...
RallyKeith Posted September 26, 2006 Author Share Posted September 26, 2006 90-94 legacy 5 speeds were 4.11 and the TURBO 91-94 were 3.90 Trust me on this one.....i have been on this road before. FWIW, If you can find a 3.90 turbo tranny you will give up a little off the line but your mileage will go up greatly (I did this swap and couldn't believe my eyes/calculations) So then you're saying that my 95 is not 4.11 or is? Link to comment Share on other sites More sharing options...
ShawnW Posted September 26, 2006 Share Posted September 26, 2006 Ask a dealership to run your VIN number or tranny code sticker to check ratio. Link to comment Share on other sites More sharing options...
Hocrest Posted September 26, 2006 Share Posted September 26, 2006 Is there a tag on the rear diff? Link to comment Share on other sites More sharing options...
subeman90 Posted September 26, 2006 Share Posted September 26, 2006 between what shawn said and what Hocrest said....that is what i would do. OR you could think of it this way: it isn't going to be a 3.9 b/c it isn't a turbo, and it "shouldn't" be a 4.44 since it isn't an OB or GT so in theroy it should be a 4.11. I'd still ask the dealer to run the tranny code or look for the sticker on the diff like Hocrest and shawn said though. Link to comment Share on other sites More sharing options...
johnceggleston Posted September 26, 2006 Share Posted September 26, 2006 when searching car-part.com, everything indicates that 95 a/t is 4.11, 95 m/t is 3.9. the 3.9 shows up in the description of rear "carrier" for 95 m/t thru 97 m/t more often than any other ratio. 95 a/t thru 98 a/t is 4.11 for 2.2L cars. this is not a garrantee. i'd call the dealer parts dept. EDIT: i also found a reference to the 4:44 ratio in the 96-99 2.5L a/t as 40 x9 teeth. if this is the case then the 4:11 ratio will have 37 teeth on the ring gear and 9 on the pinion; and the 3:9 will have 35 teeth on the ring gear and 9 on the pinion. any one know if this is acurate? and is it more or less work to swap a ring gear than a rear diff. ?? my guess is more. but knowlege is power, and more is better. john between what shawn said and what Hocrest said....that is what i would do. OR you could think of it this way: it isn't going to be a 3.9 b/c it isn't a turbo, and it "shouldn't" be a 4.44 since it isn't an OB or GT so in theroy it should be a 4.11. I'd still ask the dealer to run the tranny code or look for the sticker on the diff like Hocrest and shawn said though. Link to comment Share on other sites More sharing options...
