zyewdall Posted September 27, 2006 Share Posted September 27, 2006 Does anyone have torque curves for the stock EA81 and EJ22? I'm swapping a different engine into my '82 GL wagon, which I understand is rated stock for about 90 some ft lbs at 2400rpm. The EJ22 is rated at 137 ft lbs (for an early one) at 4,800rpm from what I can gather. The engine I'm going to swap in is rated the same 73 horsepower as the EA81, but is specced at 130 ft lbs at 1800 rpm. I want to know how that compares to the torque from the EA81 and EJ22 at 1800 rpm, because that's more the speed I'm going offroading. I suspect it might be more than even the EJ22 at that rpm, which I'd love (having driven some EJ22 conversions), but I'm not sure because it seems to be hard to find full torque vs rpm curves. What can an EA81 or a EJ22 give at say 1500 or 2000 rpm, compared to the peak torque that is published for them? Link to comment Share on other sites More sharing options...
Phizinza Posted September 27, 2006 Share Posted September 27, 2006 A guy I know dyno'd a stock EA81. Heres the resualts Link to comment Share on other sites More sharing options...
Petersubaru Posted October 8, 2006 Share Posted October 8, 2006 bostig.com has dyno results comparing a the EJ22 with another motor ...you will have to search there web site if you are not familiar with it Link to comment Share on other sites More sharing options...
Phizinza Posted October 11, 2006 Share Posted October 11, 2006 To save you all trying to log into that site here is the pictures you are after EJ22 This is on 30.5" Mud terrains in a Vanagon (what type of trans do they use?) Not perfect by any means, but nice to see. EA81 This is on stock 22.5" tyres Pitty they are two different types of dyno'ing. But you can sort of compare them. Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted October 11, 2006 Share Posted October 11, 2006 The engine I'm going to swap in is rated the same 73 horsepower as the EA81, but is specced at 130 ft lbs at 1800 rpm. ok...what diesel have you found that will fit?.......(please let it be a diesel)... Link to comment Share on other sites More sharing options...
