Brumby Boy Posted September 30, 2006 Share Posted September 30, 2006 fair enough fair enough does it have somethin to do with your post on old gen??? Link to comment Share on other sites More sharing options...
Phizinza Posted September 30, 2006 Author Share Posted September 30, 2006 your figuring this out aren't you... stop! hahaha. I need to ring around to see what a FT4WD box costs around here... Pitty you can't find this sort of thing in local wreckers. One thing I can say is my brother and I have a interesting plan on making a rear lockable diff out of a 3.7 open MY diff... More on that later. I might just go start pulling my old diff apart... Link to comment Share on other sites More sharing options...
Brumby Boy Posted September 30, 2006 Share Posted September 30, 2006 ha ha yea im trying but i dont have a whole lot of smarts i was told once so ill wait till u do it and see wat you come up with. Link to comment Share on other sites More sharing options...
torxxx Posted September 30, 2006 Share Posted September 30, 2006 beataru said: hey i was just wonderin... i dont know but.. couldnt gearoil residue flameup??? No it wont flame up if you clean the inside of the case. I used brake clean to get the oil out of the case and then pressure washed the inside of the case just to make sure the brake clean got rinsed out. One thing people need to realize, have a set of rear diff seals to install after you weld it up. All that heat will melt the rubber on the seals and you'll be pissin gear oil out. Now that its snowing up here, I need to get my welded diff installed on my car. heh, had it welded for over a month and have been too lazy to bolt it up... Link to comment Share on other sites More sharing options...
Brumby Boy Posted September 30, 2006 Share Posted September 30, 2006 Why not pull the center out, weld it then refit it? saves on seals. Link to comment Share on other sites More sharing options...
Phizinza Posted September 30, 2006 Author Share Posted September 30, 2006 The question then to ask is how do you get those bolts out on the stubs?? I had no luck and thats why the diff stayed in the case. As you can see I took the stub seals off and there wasn't much heat at the prop shaft end so I doubt I done any seal damage. It isn't leaking yet anyhow. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 30, 2006 Share Posted September 30, 2006 torxxx said: One thing people need to realize, have a set of rear diff seals to install after you weld it up. All that heat will melt the rubber on the seals and you'll be pissin gear oil out. I've welded three diffs and never had a problem with the seals yet.... GD Link to comment Share on other sites More sharing options...
torxxx Posted September 30, 2006 Share Posted September 30, 2006 GeneralDisorder said: I've welded three diffs and never had a problem with the seals yet.... GD heh, well the guy that welded mine up used 5 rods arc welding... arc seems to get A LOT hotter than mig welding. Granted he did use a lot of rod, but anyways, new seals are always a good idea. Link to comment Share on other sites More sharing options...
Phizinza Posted September 30, 2006 Author Share Posted September 30, 2006 torxxx said: but anyways, new seals are always a good idea. I agree. But really it was a spare of the moment thing... Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 30, 2006 Share Posted September 30, 2006 torxxx said: heh, well the guy that welded mine up used 5 rods arc welding... arc seems to get A LOT hotter than mig welding. Granted he did use a lot of rod, but anyways, new seals are always a good idea. Wow - that's a lot of rod, and yeah arc does get mighty hot. MIG is a lot more localized, and the sheilding gas provides better control. It gets hot, but not close to the seals. I agree it's a good idea always, but I'm cheap and none of mine were fried with a 220v Lincoln MIG.... GD Link to comment Share on other sites More sharing options...
dixracing Posted October 9, 2006 Share Posted October 9, 2006 just got done welding my 3.9 up.....i can see this will work well..........gonna give her a good rogering this weekend at tahuya..... :D Link to comment Share on other sites More sharing options...
Phizinza Posted October 9, 2006 Author Share Posted October 9, 2006 Well. After a week of having the welded diff in there we went to weld my brothers. But found mine was actually a 3.9 (front is a 3.7) So even though it off roaded good it had wrong diffs in it. So we put the welded 3.9 in my brothers car and welded a 3.7 for mine. All good now, and 3WD kinda works on the road. But it feels safer in 2WD .. I sure am missing my 4WD dirt road action. Link to comment Share on other sites More sharing options...
