brus brother Posted October 3, 2006 Share Posted October 3, 2006 Been thinkin' (always a bad omen) about cleaning MAF sensor on my 2000 GT Legacy in hopes of solving the occasional ping under certain temp/humidity conditions. I read that a dirty MAF sensor can cause everything from stuttering and hesitation (but not Tourette's Syndrome) to male pattern baldness. Could it help the pinging? Where is the sensor? Link to comment Share on other sites More sharing options...
jamal Posted October 3, 2006 Share Posted October 3, 2006 it's attached to the airbox, and you have to be really careful. I used a q-tip rubbing alcohol, and I don't think it made a difference. Link to comment Share on other sites More sharing options...
NorthWet Posted October 3, 2006 Share Posted October 3, 2006 Might want to check out this thread in the Old Gen Forum: http://www.ultimatesubaru.org/forum/showthread.php?t=63839 Link to comment Share on other sites More sharing options...
subie94 Posted October 3, 2006 Share Posted October 3, 2006 Might want to check out this thread in the Old Gen Forum:http://www.ultimatesubaru.org/forum/showthread.php?t=63839 that was useful,(thanks for putting link).i think i'll see about picking up a can of the maf cleaner. Link to comment Share on other sites More sharing options...
Manarius Posted October 3, 2006 Share Posted October 3, 2006 I wouldn't mess with the MAF unless you absolutely had to. I highly doubt it's the source of your occasional ping, Besides, cleaning them is a real pain because they're so darn sensitive that if you make one wrong move, you just fried the sensor. Link to comment Share on other sites More sharing options...
teppichkopf Posted October 3, 2006 Share Posted October 3, 2006 I bought a can of MAF cleaner the other week to try and fix a hesitation problem. Took the MAF off and sprayed it down good. It looked exactly the same when I put it on as when I took it off. So if it cleaned it I couldn't tell. In the end it didn't help nor hurt anything. (New wire set fixed hesitation problem, I was misfiring because of an arc jump.) But for $6 you could try the cleaner, might just help your problem. Link to comment Share on other sites More sharing options...
nickb21 Posted October 3, 2006 Share Posted October 3, 2006 I'm not 100% positive, but I thought that the 00-04's used MAP's and not MAF's. I think Subaru went back to MAF's in '05 (at least in the Legacy, not sure about Impreza). One of these days I'm just going to run some Seafoam through my '02... Link to comment Share on other sites More sharing options...
porcupine73 Posted October 4, 2006 Share Posted October 4, 2006 Hi '00OBW 2.5sohc here, and if it has a MAF sensor it's definitely not on the plastic intake air stuff anywhere like it is on earlier ones. I know it does have a MAP sensor. I cleaned MAF on '96 2.2L with electrical cleaner spray 'cause I thought I got air filter oil on it but didn't notice any difference. Link to comment Share on other sites More sharing options...
