monkeyhawk71 Posted October 3, 2006 Share Posted October 3, 2006 Anybody have any experience with putting larger tires on a 98 era Forester? I want to gain some clearance without wrecking my t-case or something. Link to comment Share on other sites More sharing options...
Sweet82 Posted October 3, 2006 Share Posted October 3, 2006 Slighly oversized tires shouldn't do anything to your tranny. Impreza's and Foresters are the same platform. Many a Impreza and Forester has had larger tires put on it. How big of tires were you thinking? Link to comment Share on other sites More sharing options...
jon38iowa Posted October 4, 2006 Share Posted October 4, 2006 Sweet82 said: Slighly oversized tires shouldn't do anything to your tranny.Impreza's and Foresters are the same platform. Many a Impreza and Forester has had larger tires put on it. How big of tires were you thinking? I recently replaced all four of mine ('99 Forester) with a slightly larger tire. This, as I was insistant about getting white letter tires. No problem whatsoever. I do recomend you always run four identical tires on these all wheel drive cars. John Link to comment Share on other sites More sharing options...
MountainBiker Posted October 4, 2006 Share Posted October 4, 2006 monkeyhawk71 said: Anybody have any experience with putting larger tires on a 98 era Forester? I want to gain some clearance without wrecking my t-case or something. You can't go any bigger in diamter than 215/65-16, or 215/70-15, or 205/75-15, which are all about the same size. Those tires will gain you 11mm of ground clearance, which I definitely noticed. The rear strut spring base prevents you from mounting a larger tire. If you have a 5 speed, you'll lose a bit of slow speed grunt though, due to the change in gear ratio. Link to comment Share on other sites More sharing options...
