Oil Seperator Plate questions
Hello, did a search but no luck.
I just recieved my new metal oil seperator plate for 97OBW 2.5 I noticed the plate came with new allen head bolts rather than philips head, I assume this is so that the bolts can be properly torqued? Also I noticed one of the bolts has Loctite on it and is a different part number than the others. There is also an arrow stamped in the new metal plate that points to one of the bolt holes.
Here are my questions:
What is the torque for the bolts?
What is the tightening sequence?
Where does the bolt with Loctite go? (in the hole with the arrow?)
Thanks again,
Sam
