Rims for wagon...
I have an 88 dl wagon.
I got a chance to buy (pugs) 14" rims or 15" rims... mainly for light off road and commute. ... possibly do a lift in the winter... I just want to give the car a bit of a lift with the tires...
any preference regarding the 14" or 15" rims? Will 14" make that much of a difference? and just hold out for the 15"?
seems the bigger rims have a better selection on tires... but will probably have to lift in order for the 15" tires to clear...?
your thoughts...
thanks guys, all good info... learning as I go along so great to have this board.
if you go shopping at tirerack.com, you can select any particular size you want.. and once youre looking at a tire, you can select to see "sizes & pricing" for that tire. That link goes to a chart with all available sizes for that model tire, and has tons of specs on each, including outside diameter or circumference, i forget which.... but you can compare available tires along with side-by-side comparison to stock tire size, if you want...
