monytontanarx Posted October 8, 2006 Share Posted October 8, 2006 first time Subaru owner. recently bought a 97 2.5L Legacy GT and i'm wondering where the best place to start on this car would be. i would obviously like some improvement in the performance and mileage but within a resonable price. (p.s. please feel free to let me know of any common problems with this model/ things they are notorious for) thanks a lot! Link to comment Share on other sites More sharing options...
NoahDL88 Posted October 8, 2006 Share Posted October 8, 2006 they are notorious for blowing head gaskets, if they havn't been done, then you should be very careful about over heating it. this is only for the EJ25 motor, the EJ22 is rock solid. Once the headgaskets have been replaced by an updated part, you should have no problems. The timing belt should be replaced if you don't know when it was last, when they break in the EJ25, you will ruin valves, which gets real expensive real fast. Link to comment Share on other sites More sharing options...
nipper Posted October 8, 2006 Share Posted October 8, 2006 they are notorious for blowing head gaskets, if they havn't been done, then you should be very careful about over heating it. this is only for the EJ25 motor, the EJ22 is rock solid. Once the headgaskets have been replaced by an updated part, you should have no problems. The timing belt should be replaced if you don't know when it was last, when they break in the EJ25, you will ruin valves, which gets real expensive real fast. GRRR 10-15% of production does not make it notorious. As with any aluminum engine regularly change coolant and dont let it over heat. Change the trany fluid if an automatic to avoid torque bind. not alot you can do for perfomance or mileage. They are reliable cars but a bit boring, though i like my 2.5L nipper Link to comment Share on other sites More sharing options...
jeep5.9litre Posted October 8, 2006 Share Posted October 8, 2006 Congrats on the 2.5, youre going to enjoy it Link to comment Share on other sites More sharing options...
monytontanarx Posted October 8, 2006 Author Share Posted October 8, 2006 GRRR10-15% of production does not make it notorious. As with any aluminum engine regularly change coolant and dont let it over heat. Change the trany fluid if an automatic to avoid torque bind. not alot you can do for perfomance or mileage. They are reliable cars but a bit boring, though i like my 2.5L nipper hey, thanks. sorry, torque bind?....told you i was new. Link to comment Share on other sites More sharing options...
nipper Posted October 9, 2006 Share Posted October 9, 2006 hey, thanks. sorry, torque bind?....told you i was new. look it up and open a case of beer and read. That and Head gaskets can go on for pages nipper Link to comment Share on other sites More sharing options...
Bmm001 Posted October 9, 2006 Share Posted October 9, 2006 How many miles are on it? If you don't know when any of the following was last done, the best way to improve performance and mileage is to do a tuneup: plugs, plug wires, PCV valve, air filter, fuel filter, major fluids (trans, diff, brake, coolant/thermostat), etc. Brian M. Link to comment Share on other sites More sharing options...
jon38iowa Posted October 10, 2006 Share Posted October 10, 2006 How many miles are on it? If you don't know when any of the following was last done, the best way to improve performance and mileage is to do a tuneup: plugs, plug wires, PCV valve, air filter, fuel filter, major fluids (trans, diff, brake, coolant/thermostat), etc. Brian M. Another worthy thing to keep in mind: If it ever overheats or appears to be headed that way, Turn the engine off.Subaru engines (all alluminun alloy) are very sensitive to this, moreover, I should know since I am having mine compltely rebuilt next week. John Link to comment Share on other sites More sharing options...
Virrdog Posted October 10, 2006 Share Posted October 10, 2006 How many miles are on it? If you don't know when any of the following was last done, the best way to improve performance and mileage is to do a tuneup: plugs, plug wires, PCV valve, air filter, fuel filter, major fluids (trans, diff, brake, coolant/thermostat), etc. Brian M. I second this sentiment whole-heartedly. And get extra weight out of the car, that improves performance AND gas mileage. Link to comment Share on other sites More sharing options...
