Tranny Swap Almost Done!!!!!!!!!!
OK, everything is connected in Murphy, the $500 87 T-Wag, formerly dragging a 3 speed auto tranny, now sporting a FT4WD tranny:grin:. The one little problem - the neutral saftey switch. Does that circuit extend to the shifter itself? I thought the switch was connected to the tranny itself but I closed each circuit going to the tranny and no starter activation. Any tips?
It's in the pedal assembly for the clutch. Clutch in = neutral. But the FT4WD tranny I thought also had one on the side near the reverse switch....
I know the regular D/R doesn't have one in the tranny.....
As for getting the starter to turn, it *should* just work. As long as the ECU pin isn't connected it will think it's in neutral anyway. That was how mine worked, both with a manual and an auto ECU.....
