chris in va Posted October 13, 2006 Share Posted October 13, 2006 Hey guys, I haven't been on here in a few years. I had an 87 turbo wagon for a while but sold it. Anyway, a friend of mine has a later model Justy he needs to get running. The motor got over-revved:-\ and the timing belt snapped. So we have the cover off and the belt is ready to go on. We don't know how to line up the marks though and need your help. I've asked around to a few dealerships and of course they're clueless. Link to comment Share on other sites More sharing options...
NorthWet Posted October 13, 2006 Share Posted October 13, 2006 Check out this image from the Chilton's manual: http://www.ultimatesubaru.org/photos/showphoto.php?photo=13169 Link to comment Share on other sites More sharing options...
chris in va Posted October 14, 2006 Author Share Posted October 14, 2006 Fantastic, that's exactly what I needed. Thanks a ton! Now just to find out which cylinder is TDC... Link to comment Share on other sites More sharing options...
NorthWet Posted October 14, 2006 Share Posted October 14, 2006 chris in va said: ...Now just to find out which cylinder is TDC... Huh? If I understand your question/statement correctly: The front cylinder (#1) would be at TDC. Link to comment Share on other sites More sharing options...
chris in va Posted October 14, 2006 Author Share Posted October 14, 2006 I mean which one of the three is the #1 cylinder. I'm assuming it's the one closest to the timing belt... I'll just have to pull the spark plug to be sure it's at TDC. Link to comment Share on other sites More sharing options...
ThreeEyedBandit Posted October 14, 2006 Share Posted October 14, 2006 chris in va said: I mean which one of the three is the #1 cylinder. I'm assuming it's the one closest to the timing belt... I'll just have to pull the spark plug to be sure it's at TDC. Yup, the one closest to the timing belt, there is also a mark on the cam pulley and crank pulley that you just need to line up with the marks and install the new belt. Link to comment Share on other sites More sharing options...
chris in va Posted October 15, 2006 Author Share Posted October 15, 2006 Got the marks lined up, threw the alternator belt on and started right up! Thanks for your help. Odd thing, the #1 cylinder wasn't at TDC, more like BDC. Never run into that before. Maybe #1 was on the right side of the engine? Link to comment Share on other sites More sharing options...
NorthWet Posted October 15, 2006 Share Posted October 15, 2006 chris in va said: Odd thing, the #1 cylinder wasn't at TDC, more like BDC. Never run into that before. Maybe #1 was on the right side of the engine? Are you referring to when you aligned for the t-belt? T-belt alignment is relative to t-belt alignment marks... may or may not have anything to do with TDC or BDC. The marked points are often selected to coincide with when no valves are being held open, allowing the cam to not be under tension while trying to align the marks and belt. Link to comment Share on other sites More sharing options...
RONAN Posted October 16, 2006 Share Posted October 16, 2006 Chris, I`m considiring on changing mine out also. I have an 88. Just curious, how long did it take you from start to completion??? Link to comment Share on other sites More sharing options...
javrojqu Posted March 23, 2011 Share Posted March 23, 2011 NorthWet said: Check out this image from the Chilton's manual:http://www.ultimatesubaru.org/photos/showphoto.php?photo=13169 Hi, I have a justy 88 and was thinking to change the timing belt, however I was trying to access the picture you posted of it but it was moved, is there any place or change I can get a copy or link of that picture so I can take a look at it so I can do the job on that car? THANKS. Link to comment Share on other sites More sharing options...
javrojqu Posted March 23, 2011 Share Posted March 23, 2011 chris in va said: Fantastic, that's exactly what I needed. Thanks a ton! Now just to find out which cylinder is TDC... Hi Chris, I have a justy 88 and was thinking to change the timing belt, however I was trying to access the picture NorthWet posted of it but it was moved, is there any place or change I can get a copy or link of that picture so I can take a look at it so I can do the job on that car? THANKS. Link to comment Share on other sites More sharing options...
Turbone Posted March 23, 2011 Share Posted March 23, 2011 I'm posting a off site link because the pics posted were very old and were lost during some forum changes. http://subarujusty.proboards.com/index.cgi?action=gotopost&board=engine&thread=3875&post=25650 Link to comment Share on other sites More sharing options...
