subeman90 Posted October 14, 2006 Share Posted October 14, 2006 here is something that I found while doing a search. It was written by GeneralDisorder. Anyone have anything to add to this or more precise locations of bolts, nuts, etc.? I want to get a new dash for the 83 and i might have found one..... thanks for all input GD's post: As for removal tips - I just did this job on Saturday, and I can say that removing the windshield (10 minutes with a utility knife) will really make getting to the bolts on the top of the dash much easier. Of course you can't do this on your car, but at the junk yard it certainly would fly, and make your visit more enjoyable. With the windsheild out, it shouldn't take more than 30 minutes to get the dash out. I had never pulled one before either, but if you know where all the bolts and nuts are, then it's actually pretty straightforward. Remove the surround, and the guage cluster first, as well as the drivers side kick panel. Remove the glove box door, and insert. And remove the passenger kick panel/shelf. On top of the dash remove the vent louvers, and there will be three or four bolts underneath that hold the dash down.... various nuts and bolts underneath that hold the dash in place, and of course all the wireing has those wraps on it that hold it to the dash. Couple of zip-ties in there too. I just cut those. GD Link to comment Share on other sites More sharing options...
Turbone Posted October 14, 2006 Share Posted October 14, 2006 3 bolts on top, one on each end and one in the middle. A real biotch to get out, use a 90deg phillips. Theres a bolt underneath of each end, once you get access to it you will see it. To remove the center louvers theres a small piece of plastic inbetween the vents. Remove it to access 2 screws. I suggest removing the steering colume, it makes life much easier. The cable for the vent control on top can be another PIA, but it needs to come loose too. The wiring for the heater controls also disconnect, lots of other little wire connectors here and there also. Thats it in a nutshell, besides the obvious stuff GD mentioned. Link to comment Share on other sites More sharing options...
NorthWet Posted October 14, 2006 Share Posted October 14, 2006 Those dash-top screws have a 10mm bolt head on them (at least on the one I pulled), so a 10mm 1/4"-drive socket/ratchet will get them (I forgot mine ), as will a 10mm ratcheting box-end wrench (again, forgot mine )... or a 10mm combo-wrench and a lot of patience. Once I got those top screws out (45 minutes with my wrong tools and time to let my hands uncramp) it was pretty simple to pull the rest. But then, I had the advantage of having a pulled-out example in my van that I could look at beforehand. Link to comment Share on other sites More sharing options...
Turbone Posted October 14, 2006 Share Posted October 14, 2006 Thanks for correcting that Pat. Its been so long since I've done a dash I forgot they were bolt heads not screws:rolleyes: That, and my CRS is getting worse. Link to comment Share on other sites More sharing options...
subeman90 Posted October 14, 2006 Author Share Posted October 14, 2006 Thanks a bunch both of you guys! I hopefully will be going after it next weekend so we will see how it goes then. Thanks again! Link to comment Share on other sites More sharing options...
beataru Posted October 14, 2006 Share Posted October 14, 2006 i didnt read it because i know exactly how to get it out... BIG hammer BIG Prybar and a bad temper= destruction... oh you want to keep it you say well then never mind... Link to comment Share on other sites More sharing options...
kgrove56 Posted September 19, 2015 Share Posted September 19, 2015 Ok how hard to put back in. It's always easier to take apart than to put together Link to comment Share on other sites More sharing options...
jono Posted September 19, 2015 Share Posted September 19, 2015 have done several now, two hours out, 2.5 back in. With the heater/ vent control panel it can remain in the main structure of the car if you undo the screws holding it in place and juggle it back through the frame it sits in. Means you only need undo the fresh air in cable at the other end and not disconnect hot cold cable. I was once put off this project by a Subaru specialist workshop by him saying first step in the manual is remove windscreen. The right number of 10mm spanners, sockets n stuff allows the first step to be bypassed. For future access needs, I made one inch holes in the vent cover plastics that cover the three 10mm headed bolts and put one inch rubber bung plugs in place Link to comment Share on other sites More sharing options...
hatchsub Posted September 21, 2015 Share Posted September 21, 2015 Eh I've done a few EA81 dashes. Not that bad really. I lucked into one in a junkyard and i think i had it out in about an hour even. The hardest part if i remember is getting at the 10mm bolts that are hiding under trim up near the windshield but you can do it without taking the windshield out. You just need a very small socket set that fits back there. Link to comment Share on other sites More sharing options...
kgrove56 Posted September 21, 2015 Share Posted September 21, 2015 Wish you lived by me I would pay you to do getting hard to craw under the dash and my eye sight ain't what it use to be I have a cherry dash to put in and my windshield is out Link to comment Share on other sites More sharing options...
