Power to fuel pump
The power to the pump will be cut off if the ignition system isn't working. The power is also tied to the pump through a relay so these areas need to be checked. The pump may just be bad also so check to see if voltage is getting to the two leads going to the pump. If you have 12 volts there and the pump doesn't run then the pump windings would be appear to be open.
jack the car up, four corners, jackstands. be outside. start car, climb underneath (CAREFUL but i HOPE that goes without saying.. MUST HAVE A BUDDY AROUND) jiggle the wires to the fuel pump. see if you can get it to die.
it could be a bad wire.
