185/80's = slow?
AKIRA
I want to get a set of cooper weathermasters in 185/80, which is about 24.8 inches.
the question is how much will it slow down my car?
I checked and it will change the gearing to about .264 taller, making first gear about 3.9, if that helps.
AK
I'm running 185/75/14, which is just a touch bigger than the 185/80/13. They are mounted on Pug wheels, which are substantially heavier than the 13 inch soob steel wheels. I haven't noticed a drastic power loss. But then again, If I put on some 13 inch soob alloys with little tires on them, I might change my mind. those things don't weigh anything at all:D
On my turbo wagon, I went from 175-70's to 185-80's. I noticed that I wasn't spinning my tires as much on "slippery" starts, i.e. gravel on pavement.
Other than that, it seemed like it still accelerated well, and I didn't notice a fuel economy difference either.
This is easy as hell for me to answer.. considering I ran one of the taller tires on usmb of 235/75R15 (30x9.00R15)
155/80R13 kicks rump roast for peeling out and making your BRAT (what i had it on) look alot more powerful.. 155/80's can take you offroad just fine also.
165/80R13.. u can now tell the instant difference between 155 and 165 :D 155 was a funner tire than 165.
175/80R13.. this is right about where u wanna be.
185/80R13.. this is right about where u wanna be.
195/80R13.. big and dopey (for stock).. still work ok
205/70R14.. This is where you have to start to be critical.. this size and larger wheels/tires will result in gear loss.
215/70R15.. These are like pulling a small vehicle behind your wagon, like a waaaay light hatch. You can definately feel the loss in gear now. Its almost gone.
225/70-80R14-15.. never ran these.
235/75R15!.. your gearing is 95% gone. Horsepower is lost. Bearly tolerable. Going back to 205/70R15 if possible. Btw: O/D on these tires were 30x9.00R15 .. waay bigger than my stock 165/80R13's. (22x6.5R13?)
Ok.. btw, i had SINGLE RANGE PUSH BUTTON 4WD! im sure D/R would have ALOT easier of a time. With the 235's on, it was HARD to get moving around, alot of clutch work. Another note: S/R = 1:1 gear ratio D/R = 1.4:1 ... so hassey and someone else with 31x10.50R15 tires have like no gearing so their rigs are pretty much gutless.
With enough said.. you will notice alot EVERY time you move a section width to a wider one. Also, I ran EVERY size up there. IMO: 205/70R14 would be the best for our subarus S/R or D/R. (when offroading)
Sorry i just posted so freekin much.
Aki:
I ran that size snow tire last winter on my 93 Loy 4wd wagon. I liked them very much, and will be using them again this winter. The height was nice for heavy snow, and they performed well in all types of weather.
I thought they were actually a little quicker than what I was driving before winter (195/55/15's on Pug alloys).
John
