gear oil leak
Well, looks like my 82 4WD wagon has a gear oil leak somewhere in the manual transmission, I got under, looked, and cant seem to see where the leak is coming from. I placed some cardboard underneath and it looks like its coming right from the center of the transmsmisson. I checked the plug and it was tight and could not see any leaks around it.. Im stumped because everytime I go to drive the car, the fluid is on empty on the dipstick...any suggestions?? You guys ever had this happen?
If you can't see where the oil is leaking from (I assume the case is cleaned, etc.) You could try flourescent dye and a black light. I'm not sure if there is a specific dye for oil, but with that leak rate, I don't think the A/C dye would hurt.
  • 5 months later...
good luck finding that shift shaft seal, even the dealer couldnt souce one for me.
my subaru leaks from the 4wd hi light switch its on the drivers side bottom of the trans behind the axel, the old tranny i replaced leaked pretty good from there too.
-Sam
