PorSubaru Posted October 19, 2006 Share Posted October 19, 2006 Where is a good website/store/autoparts that sells exhaust studs for an EA82T engine? I found the gaskets online but now I need the studs. input appreciated. Link to comment Share on other sites More sharing options...
idosubaru Posted October 19, 2006 Share Posted October 19, 2006 i haven't found any parts place that carries a direct fit stud. but...all good autoparts stores have one that will work. it's not exact, but works great. i've bought them many times. best bet is to go match them up and get the closest one. the auto parts stores will have ones that have a small un-threaded middle portion maybe a 1/4" wide. put the short threaded end in the engine side hole so the nut doesn't run into the unthreaded portion of the stud. (if that sounds confusing, it's really simple). almost all decent stores that have parts bins have these studs. but they won't be able to match them up by part number or computer, just look. i think they're 10x1.25 pitch threads. the harder thing to find is the thin walled nuts they use on those exhaust studs. they are nice for ease of use, but don't think they can be bought except used. Link to comment Share on other sites More sharing options...
Gloyale Posted December 28, 2006 Share Posted December 28, 2006 Also make sure that the threads in your heads for the stud are still good. Lots of times if the stud comes out, it takes alot of aluminium with it. It is sometimes nessecary to use a slightyly larger stud. I think either 3/8 or 7/16 standard studs work. Whatever is slightly bigger than the stock ones. This leaves you the option to drill out and go one bigger to the next metric size if it strips again. I've had do do this countless times, but I still can't remeber which size of the top of my head. Just make sure when you tap out the new threads not to drill any deeper than the original hole or you'll hit an oil passage. Link to comment Share on other sites More sharing options...
trikerbob Posted December 28, 2006 Share Posted December 28, 2006 I found exhaust studs the other day at Kreagns Auto parts on one of the little round turn style type racks all the parts stores have. Wasn't looking for them, just came across them and remembered that I was missing them on one side. They are 10mm Fine thread. Bob Link to comment Share on other sites More sharing options...
subiekid Posted December 29, 2006 Share Posted December 29, 2006 If your threads pull out, I have had great results using 7/16 studs to replace them. Plus SAE studs are easier to get ahold of than metric (lowes/home depot usually carry them). The threads in the head are M10x1.25, napa will either have or can order the correct studs with no unthreaded portion. Scott Link to comment Share on other sites More sharing options...
