Are you pressing on the brake when you try to take it out of park? Sounds like there's some issue with the setup that normally energizes a solenoid when the key is on and the brake is pressed and the lever is in park. The first question would be can you hear the 'click' when pressing the brake under these conditions?
yes im pressing on the brake and i do here the click
Im also getting a clunking noise frome the rear axle when i turn the car,would this be torque bind ? I bought the car for $250 because of blown head gaskets and just started driving the car today. everything is working good except the shiffter and the clunking coming from the back.The owner before me was also driving the car around on the temp tire in the back.
