Spider gears in open vs VLSD same?
Does anyone who's swapped a VLSD into an open diff case know if the spider gears are the same?
I just got a 4.111 VLSD with c-clip stub axles real cheap, but the concave washers that sit behind the spider gears are broken. The teeth on the gears aren't too bad, I just want to know if the washers in my open 3.9 diff will fit before I pull it apart.
Jeremy
