Suborsche Posted October 23, 2006 Share Posted October 23, 2006 Hey guys, my name is Conrad. I live in Bellevue, Wa and just recently bought a 1983 Subaru GL Wagon to be my winter vehicle and mountain goat. I have been looking for a cheap subaru for a while and found this car on craigslist. The ad said it only drove in 4WD and needed some work. My buddy Galen (carfreak) and I checked it out...thinking it was just a broken axel. Another member Ed gave us some great advice and told us to put the car in 2WD...let out the clutch and try to drive it. If the axel spins but the wheel doesn't its probably a broken hub. The car did exactly that, but otherwise drove well. I offered the lady $200 bucks for it and drove it home that day. Upon further inspection I realized not only was the hub bad, but the rotor was grinded away and the caliper was shot. I'm guessing the previous owner crashed it into a ditch. After ac couple junk yard runs, 2 axels, 2 tie rod ends , a hood, a control arm, a rotor, caliper, and hub later we have a drivable car that needs an alignment. I just took it for a spin and even though I bled the brakes the pedal is still very mushy, and the car makes a grinding noise when I brake....I think its the drums. Also, the car will start up fine, idle a little high at first but after I've been driving it 5 min and take it out of gear the idle slowly drops until the car dies. Any ideas as to what's causing that? The car is a work in progress but will hopefully be roaming the streets this week. Here are some pics for your enjoyment: The finished product Some front end damage. The bumper is so bent the cover is held on by wire. RED PIMP INTERIOR! Does anybody know how to get a seat from the E82's to fit in my car? Old parts My garage kept baby with the soob outside Quote Link to comment Share on other sites More sharing options...
Suborsche Posted October 23, 2006 Author Share Posted October 23, 2006 Ahhh... how do I upload images? Quote Link to comment Share on other sites More sharing options...
ShawnW Posted October 23, 2006 Share Posted October 23, 2006 Top of any USMB page click photos. Quote Link to comment Share on other sites More sharing options...
Suborsche Posted October 23, 2006 Author Share Posted October 23, 2006 Photos: http://www.ultimatesubaru.org/photos/showphoto.php?photo=13234&cat=500&ppuser=20916 Quote Link to comment Share on other sites More sharing options...
jeep5.9litre Posted October 23, 2006 Share Posted October 23, 2006 Good Lookin wagon!! Good luck Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 23, 2006 Share Posted October 23, 2006 Any ideas as to what's causing that? Poorly maintained carburetor. Time to take a trip into the ancient art of carb rebuilding. Or just get a Weber. GD Quote Link to comment Share on other sites More sharing options...
Suborsche Posted October 23, 2006 Author Share Posted October 23, 2006 Yeah, I'd love to get a weber. Anything I can do to maintain its drivability before that day comes? Quote Link to comment Share on other sites More sharing options...
hatchsub Posted October 23, 2006 Share Posted October 23, 2006 couple of things you can do for it. Cheap easy way is to get some carb cleaner and spray it down the carb with the car running. Another is to use that cleaner and spray around the base of the carb and intake gaskets as these are usual areas of vacuum leaks which could cause an engine to do what you described. If the idle picks up when you do this you found your leak. Good luck. Quote Link to comment Share on other sites More sharing options...
Suborsche Posted October 25, 2006 Author Share Posted October 25, 2006 Will a webber off an EA82 fit my EA81? Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted October 26, 2006 Share Posted October 26, 2006 Yes but there are certain kinds. DGV will fit as well as a similar one the DGF, I think... Just get an adapter that matches your intake manifold and check out the USRM. Quote Link to comment Share on other sites More sharing options...
