Help please
I pulled my valve covers off today to replace the gasgets, and there was a plug sitting in each head. It was the same plug on each side. What does that mean? I tapped each one in as well as I could, But neither one went all the way in. Will this cause me any problems later? Thank you.
You ever run this engine? Sounds like those are freeze plugs.... did the engine freeze at some point with only water in the cooling system?
It might have, I went away for a year, and while I was gone my friend pulled the engine.
Yeah - you are going to want new freeze plugs - usually once they have popped out they are not good to reuse. You don't want them to leak....
It probably froze with only water in the engine - the ice expands and blows the plugs out - it's a good thing because otherwise it would crack the heads or block.
There are 3 per head, 1 on each side and 1 in the top middle, how do you install those? Thanks for the help, with my clutch and this problem GD.
They are steel, and are basically just a friction fit. You will see the new ones you get are concave and the edges have a wedge shape. Use a socket that is near the same diameter with an extension on it to pound them in.
No problem on the help - that's what we are all here for. Even I have questions now and then :eek:
Oh - and you probably only need to replace the ones that have popped out ;)
Ok so yesterday I couldnt get the plugs out, and I didnt want to pull my head (though I probably should have), so I just pulled off the rocker arms, and took a 14mm socket and pounded the plugs the rest of the way in. Will the plugs be prone to popping out now, and if they do come out, how will I know?
