Dr. RX Posted October 23, 2006 Share Posted October 23, 2006 The odometer had 85,000 miles on it when I did the conversion, I just passed 120,000 miles this morning on the way into work, so that means that I have 35,000 miles on my conversion with very little (nothing unusual) problems. So, how many miles do others have on their conversions? Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted October 23, 2006 Share Posted October 23, 2006 One member that I know has had alot of good miles on his conversion is Beefaru.He has an ej22 swapped into his ea82 wagon.He will have to say exactly how many miles he has put on since the conversion,but I know it is over 100k.Beefaru's wagon is really nice. Link to comment Share on other sites More sharing options...
suberdave Posted October 23, 2006 Share Posted October 23, 2006 i just turned over 10K on my EJ20G swaped wagon. i have not had a single problem. i havent even put new spark plugs in it yet. (need to do that soon). i love it couldn't be more happy. best thing i have done for my little silver wagon. -=Suberdave=- http://www.suberdave.com Link to comment Share on other sites More sharing options...
NoahDL88 Posted October 23, 2006 Share Posted October 23, 2006 Dont know exact mileage, but its been from michigan to san diego and now to seattle, plus all around here since. Link to comment Share on other sites More sharing options...
Dr. RX Posted October 23, 2006 Author Share Posted October 23, 2006 i just turned over 10K on my EJ20G swaped wagon. i have not had a single problem. i havent even put new spark plugs in it yet. (need to do that soon). i love it couldn't be more happy. best thing i have done for my little silver wagon. -=Suberdave=- www.suberdave.com Dave, I haven't changed the plugs yet either, the only problem that I have had was that the temp sensor went out, it is a bear to get to without tearing the top of the engine all apart. Link to comment Share on other sites More sharing options...
Matty B Posted October 23, 2006 Share Posted October 23, 2006 65,000 kilometres since the EJ swap, 18,000 since the blower went on and the boost arrived. I wouldn't say I have had no problems, but it runs like a good thing. Every morning! Link to comment Share on other sites More sharing options...
Snowman Posted October 23, 2006 Share Posted October 23, 2006 I put around 15,000 trouble-free miles on my EJ swap before I parted the car out for non-drivetrain-related reasons. Link to comment Share on other sites More sharing options...
Numbchux Posted October 24, 2006 Share Posted October 24, 2006 I've put about 2,000 on it since I got it running in August. once I got the connections resoldered at the Crank Angle Sensor, I haven't had a problem since. little hard starting in the cold, I think I'll put the wire for the block heater back in, and change the oil for some 5W-30. Link to comment Share on other sites More sharing options...
WoodsWagon Posted October 24, 2006 Share Posted October 24, 2006 6,000 since early august when it went in. Problems: Burning lots of oil, my fault, I screwed up rebuilding the motor. That and it's a lot easier to abuse the snots out of the rest of the car. Something about having the front of the car lift in response to the gas pedal is satisfying. I have occasional CEL's tripping, but that has to do with my new 02 sensor drowning in oil. 1qt a week is bad news. Link to comment Share on other sites More sharing options...
Numbchux Posted October 24, 2006 Share Posted October 24, 2006 I have occasional CEL's tripping, but that has to do with my new 02 sensor drowning in oil. 1qt a week is bad news. oh man. that is bad! I'm throwing an CEL because I haven't hooked up the vehicle speed sensor....maybe one of these days I'll get around to that.... Link to comment Share on other sites More sharing options...
WoodsWagon Posted October 24, 2006 Share Posted October 24, 2006 The VSS is easy. I pulled the insrument cluster, then spliced labled wire to the tach, VSS, coolant temp, and oil pressure gauges. The vss and tach tie right into the PCM. Link to comment Share on other sites More sharing options...
Numbchux Posted October 25, 2006 Share Posted October 25, 2006 The VSS is easy. I pulled the insrument cluster, then spliced labled wire to the tach, VSS, coolant temp, and oil pressure gauges. The vss and tach tie right into the PCM. oh, I know. you don't even need to pull the cluster. but I just didn't have time when I finally got the thing to run. and I haven't made the time since (still haven't been able to make the blasted defroster work) Link to comment Share on other sites More sharing options...
BeefaRu Posted February 4, 2007 Share Posted February 4, 2007 Jerry brought up mine so here it is. Lets see - the 2.2 had around 10k on it when it was installed in 1996. So thats 10 years, and I've been through 20 states with it. It has a total 186,400 miles on the conversion. The odometer was reset when the conversion was done. I'd shave about 5,000 off though because of wheel/rim differences and the spedometer runs 3mph high. --E Link to comment Share on other sites More sharing options...
Subarutex Posted February 4, 2007 Share Posted February 4, 2007 Ultimate is closing in on a thousand... My wagon... maybe 1 mile, and thats being generous Link to comment Share on other sites More sharing options...
tizzle Posted February 5, 2007 Share Posted February 5, 2007 I'm at about 37,000 on my swap Link to comment Share on other sites More sharing options...
Uberoo Posted February 6, 2007 Share Posted February 6, 2007 how long should my EJ last?is at 202K...thats before even swaping it in... Link to comment Share on other sites More sharing options...
baccaruda Posted February 6, 2007 Share Posted February 6, 2007 depends on how well it's been and will be maintained... how long is a piece of string? Overall they're a good motor.. the EJ22 and the EA81 are the best Subaru motors ever according to many people. I lack enough experience with the EJ22 for that bandwagon.. Link to comment Share on other sites More sharing options...
Numbchux Posted February 6, 2007 Share Posted February 6, 2007 how long should my EJ last?is at 202K...thats before even swaping it in... my donor car had 230k on it. I've put almost 20k on it since then....still runs like a top. 160psi compression at all 4 corners. PP6 and boost to come this summer.... they're bullet-proof. if they haven't been over-heated or run out of oil, that is. Link to comment Share on other sites More sharing options...
Snowman Posted February 7, 2007 Share Posted February 7, 2007 The VSS is easy. I pulled the insrument cluster, then spliced labled wire to the tach, VSS, coolant temp, and oil pressure gauges. The vss and tach tie right into the PCM. Hold up! I thought I checked on the VSS issue when I did the swap in my 86, and it looked to me like the voltage range was different between that and the 92 EJ22 that I swapped in. Did I miss something? Link to comment Share on other sites More sharing options...
