incognito Posted November 11, 2003 Share Posted November 11, 2003 Well.. in the link im gonna give you guys theres two problems: i broke a purge control solenoid (located right next to the thermostat on my ea82) and i dont even know what the hell these are (green nipples) but the one that is broken goes down to that big canister (PCV?) thats near the transaxle on the drivers side. Can anyone give me a heads up to what the hell these do to my car if left broken? First off my car aint runnin anymore, so thats one i figured myself. What are these gonna cost me? Any other opinions u guys have for this kind of situation? BTW: i got her home via duct tape. she aint leaving that way. Link to comment Share on other sites More sharing options...
incognito Posted November 11, 2003 Author Share Posted November 11, 2003 oops.. forgot the link like a *******. http://usmb.net/gallery/albuo01 Link to comment Share on other sites More sharing options...
calebz Posted November 11, 2003 Share Posted November 11, 2003 Jon, the ones with the green nipples are the solenoids for shifting in and out of 4wd on a pushbutton manual tranny. they can be had froma junkyard fairly cheap, and from what I have seen, they don't generally go bad.. I'm sure someone on the board here has one they would send you cheap Link to comment Share on other sites More sharing options...
incognito Posted November 11, 2003 Author Share Posted November 11, 2003 ok i remember i broke that one before and had trouble gettin in and outta 4wd.. note only 1 is broken... So would having a broken purge control solenoid not allow my car to start? btw; thx calebz for the answer. Link to comment Share on other sites More sharing options...
calebz Posted November 11, 2003 Share Posted November 11, 2003 Between the brokern PCS(provided its causing a vacuum leak) and the probable vacuum leak caused by the broken 4wd soleniod, That might be enough to make the car not start. Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 11, 2003 Share Posted November 11, 2003 If you need the soleinoid i got em, shippng and handeling and there yours, may still be cheaper in the junk yard though Link to comment Share on other sites More sharing options...
electryc_monk Posted November 11, 2003 Share Posted November 11, 2003 I'd say pack it up and wait for the go ahead ... that's mho anywho.... after all the odds of finding it in his neck of the woods seems kinds difficult at the idealistic best. Well B_W_M, am I even close to correct on that one? Link to comment Share on other sites More sharing options...
incognito Posted November 11, 2003 Author Share Posted November 11, 2003 NoahDl88, which ones do u have? the green nippled ones or the actual purge solenoid valve? Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 12, 2003 Share Posted November 12, 2003 I have everything but the stuff on the tranny and a few hoses, i did the dual range conversion so i have just about everything sorry bout the wait Link to comment Share on other sites More sharing options...
incognito Posted November 12, 2003 Author Share Posted November 12, 2003 can u send me a couple pics? kronbach09@hotmail.com Thx Noah! Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 13, 2003 Share Posted November 13, 2003 I don't have a digi cam, but i'm in the res halls so someones bound to have one, which one did you need the one by the wiper motor or the purge control solenoid, i should have both , the green one definately, i'll look for a camera to load pics tomorrow Link to comment Share on other sites More sharing options...
incognito Posted November 13, 2003 Author Share Posted November 13, 2003 ok if u look at the drivers side strut tower from the drivers side fender area, you'll see the two green solenoids. I need the Left side as u could see in the pics. The other is the "Purge Control Solenoid" located near the thermostat. Thanks for your help noah, pm me when u get pics and ill send u info. Link to comment Share on other sites More sharing options...
incognito Posted November 14, 2003 Author Share Posted November 14, 2003 http://usmb.net/gallery/albuo01 BTW: Noah, before u go doin anything, make sure its these two items. I believe I can explain; that purge control sylenoid? has a hose that runs up to a container thingy? behind the passenger strut tower and then over to the green nippled vacuum valves behind the strut tower on the drivers side. On the purge control? if looking directly down on your spfi, it would be the basically ontop of the thermostat housing. *(in the pic, one of the thermostat bolts can be seen to the bottom left next to that green connector)* I'm here if ya got any more questions. Link to comment Share on other sites More sharing options...
