carfreak85 Posted October 26, 2006 Share Posted October 26, 2006 Need advice on how to do this. I got all four bolts off but the thing is Very stuck. I can rotate it, but it refuses to come stright off. What methods have you all tried? Link to comment Share on other sites More sharing options...
WheaT_BeeR_MaN Posted October 26, 2006 Share Posted October 26, 2006 actully i just did my first 1 yesterday on my 83. i had a little trouble getting that last bolt up on top. but anyways all i did was grab the filter and pulled back and forward with pressure out. im sure u tried this so im thinking use something else on the other side for leverage. good luck. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 26, 2006 Share Posted October 26, 2006 DON'T pry on it. You will break it. If you must pry apply a *very* slight force while twisting. Work it back and forth and pull at the same time. It's a lot easier from under the car. Just keep working it and it will come off. GD Link to comment Share on other sites More sharing options...
carfreak85 Posted October 26, 2006 Author Share Posted October 26, 2006 DON'T pry on it. You will break it. Too little, too late... Hopefully the one off my 1600 donor engine will mate up. Thanks for the help guys! Link to comment Share on other sites More sharing options...
ShawnW Posted October 26, 2006 Share Posted October 26, 2006 1.6 one doesnt fit the 1.8. Use the filter as a handle to pull on it with. Ive broken 4 of these in the car and alot more off the car tearing down engines. Don't sweat it. A new one shouldnt be more than 100 and its good piece of mind. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 26, 2006 Share Posted October 26, 2006 Discount import parts here in portland has them for around $65 - Parut too which is the OEM for Subaru. As shawn says - 1600 is definately different, and will not fit. GD Link to comment Share on other sites More sharing options...
backwoodsboy Posted October 26, 2006 Share Posted October 26, 2006 I got an OEM pump this past summer for my ea81 from RockAuto.com I think it was like 65 bucks:banana: Link to comment Share on other sites More sharing options...
