chadwick35/04 Posted October 26, 2006 Share Posted October 26, 2006 I have a 2004 subaru legacy 35th anniversary edition sedan and I am coming up upon 30k, and I am getting ready to have my 30k done now, I have had the air filter replaced at my last oil change and I do not need my tires rotated or rebalanced due to new tires and a four wheel alignment. Now I thought that the spark plugs on the 2004's do not need to be done till 60k and I know the fuel filters on the 2004's are internal and do not need replacing also they are good for the life of the car. So I am having all the fluids replaced such as transmission,brake,coolant,oil,rear diff and the pcv valve replaced also. So if someone could let me know about the spark plugs I would appreciate it! I think other than that the 30k will be complete and I will be ready before winter comes, anything else I should do let me know thanks all!: Link to comment Share on other sites More sharing options...
ShakotanBoogie Posted October 26, 2006 Share Posted October 26, 2006 If yer worried about the plugs just do 'em yourself. Cheap as hell and easy. Link to comment Share on other sites More sharing options...
porcupine73 Posted October 26, 2006 Share Posted October 26, 2006 Maybe change coolant/antifreeze. What does your manual show for spark plug replacement interval? Probably just depends if you have long life plugs (such as platinum or iridium) in it. Is this an MT or AT? If AT you could add front diff gear oil to the list (assuming on the '04 AT's the front diff still doesn't share oil with the ATF). Could also consider changing PS fluid. Link to comment Share on other sites More sharing options...
outback_97 Posted October 26, 2006 Share Posted October 26, 2006 Here's a link to Subaru's recommended maintenance schedules: http://www.cars101.com/subaru/subaru_maintenance.html Plugs at 30K for your engine. I believe all this is in your owners manual too. And are you sure about the fuel filter? Never heard of one that's good for the life of the car. That doesn't sound right. Steve Link to comment Share on other sites More sharing options...
outback_97 Posted October 26, 2006 Share Posted October 26, 2006 Also a google search on "subaru recommended maintenance schedule" yields this, click on the link at the bottom of the page for a popup of the source of the cars101 link I posted earlier: http://www.subaru.com/owners/schedules/index.jsp?navid=SCHEDULE_2004 Might as well get it straight from the source. Steve Link to comment Share on other sites More sharing options...
ericem Posted October 26, 2006 Share Posted October 26, 2006 Wow, thats alot of maintenance for a car with 30k, i would leave it till atleast 140k MILES so 200,000KM lol. Im at 289,%^&KM and oriniginal brake fluid, just got the rear diff oil changed, need to change the front oil, tranny fluid needs to be changed(only changed tranny fluid ONCE and my dealer probably did fill it up full, and it would not shift into 4th gear, but i had no evidence, 2000CDN later and i got a rebuild, and THE WARRENTY is 100,000km, i was at 100,123, AWW), rad got flushed at 260,000km when water pump was replaced, and just engine oil. And here i am today! Link to comment Share on other sites More sharing options...
Manarius Posted October 26, 2006 Share Posted October 26, 2006 Wow, thats alot of maintenance for a car with 30k, i would leave it till atleast 140k MILES so 200,000KM lol. Im at 289,%^&KM and oriniginal brake fluid, just got the rear diff oil changed, need to change the front oil, tranny fluid needs to be changed(only changed tranny fluid ONCE and my dealer probably did fill it up full, and it would not shift into 4th gear, but i had no evidence, 2000CDN later and i got a rebuild, and THE WARRENTY is 100,000km, i was at 100,123, AWW), rad got flushed at 260,000km when water pump was replaced, and just engine oil. And here i am today! Your car is wayyyyyy different from a 2000. Cars nowadays are much less tolerant than the older cars. I think the 30k maintenance is excessive, but the 60k maintenance is not. Link to comment Share on other sites More sharing options...
ericem Posted October 26, 2006 Share Posted October 26, 2006 Your car is wayyyyyy different from a 2000. Cars nowadays are much less tolerant than the older cars. I think the 30k maintenance is excessive, but the 60k maintenance is not. ya ur probably right about that. That bites, but someone has to make money :-\ Link to comment Share on other sites More sharing options...
porcupine73 Posted October 26, 2006 Share Posted October 26, 2006 That '04 maint schedule does show to inspect a lot of things, but the items to actually do such as replace coolant, engine oil, fuel filter (why does the wrx sti have double the replacement interval for fuel filter), air cleaner, brake fluid, rotate tires seems pretty straight forward. ATF and gear oil replacement are suggested under 'severe service' which some drivers will qualify for based on their description. Link to comment Share on other sites More sharing options...
NoahDL88 Posted October 27, 2006 Share Posted October 27, 2006 Maintenence, pay now, or pay more later. I'd get the coolant flushed, ATF flush, LOF, and the fuel filter probably isn't a bad idea, even if it is a "lifetime" part, unless they have to drop the tank. Link to comment Share on other sites More sharing options...
Tech1967 Posted October 28, 2006 Share Posted October 28, 2006 Lifetime or no maintenance parts are few, especially filters, but it's a nice selling point. There is an access panel inside the vehicle, no tank drop. I think they give me about .3-.5 to replace. Link to comment Share on other sites More sharing options...
