hatchsub Posted October 29, 2006 Share Posted October 29, 2006 So when hocrest and I pulled the tranny from the junk car there was a wiring harness on the drivers side of the tranny with two wires going to it. We unplugged it and snagged it as well. Is this my reverse harness? Will it just plug in place of my auto one and give me reverse lights? Probably not huh? Quote Link to comment Share on other sites More sharing options...
kayakertom Posted October 30, 2006 Share Posted October 30, 2006 Use an ohm meter and test for continuity of the two wires when the trans is put into reverse to tell if it is the reverse switch. You will likely need to clip off the connector and add wire lengths to bring the leads to the electrical connector by your shifter. You can figure out the appropriate two pins to connect to by either using the meter on the auto shift mechanism or a wiring diagram. You can solder the ends and jam them into the connector. Be careful routing your wires so that they don't interfere with the shift linkages. So when hocrest and I pulled the tranny from the junk car there was a wiring harness on the drivers side of the tranny with two wires going to it. We unplugged it and snagged it as well. Is this my reverse harness? Will it just plug in place of my auto one and give me reverse lights? Probably not huh? Quote Link to comment Share on other sites More sharing options...
hatchsub Posted October 30, 2006 Author Share Posted October 30, 2006 um is that to convert from auto to standard? because i didnt state that earlier. Im converting from auto to stick shift. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 30, 2006 Share Posted October 30, 2006 Your reverse harness is one of the plugs where the auto shifter was inside the car. It appears from my 83 FSM that you are looking for the Blue/white wire and the Green/yellow wire on the 4 prong inhibitor switch connector of the auto shifter for your reverse lights. Hook those to the reverse switch from the manual transmission and you should be in buisiness. GD Quote Link to comment Share on other sites More sharing options...
Durania Posted October 30, 2006 Share Posted October 30, 2006 I take it since you wanted to sell it before since it was auto, Your going to keep it now since your doing the manual swap? Quote Link to comment Share on other sites More sharing options...
hatchsub Posted October 30, 2006 Author Share Posted October 30, 2006 I take it since you wanted to sell it before since it was auto, Your going to keep it now since your doing the manual swap? OH YEAH.. the main reason i was selling it was cause it was too sluggish. Now that im going to do the swap im def keeping it. Quote Link to comment Share on other sites More sharing options...
hatchsub Posted October 30, 2006 Author Share Posted October 30, 2006 Your reverse harness is one of the plugs where the auto shifter was inside the car. It appears from my 83 FSM that you are looking for the Blue/white wire and the Green/yellow wire on the 4 prong inhibitor switch connector of the auto shifter for your reverse lights. Hook those to the reverse switch from the manual transmission and you should be in buisiness. GD Thanks GD. Now is there any place that i should route the wires? Im thinking that up through that hole behind the shock tower on the drivers side where the main harness goes would be a good place to route the wire. I dont think i would want to route it through the shift hole. Or is there another hole that would be closer to it? Also is there something i have to hook up so that the car will think its in park or neutral to start it? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 30, 2006 Share Posted October 30, 2006 If *I* were doing it, in the intrest of making it easy, I would drill another hole (say 1/2") next to the big shifter hole, and run the wires through there with a common rubber "grommet" and some quality zip ties to keep the wire in check around all that moving metal. That way you don't have to cut into the big grommet behind the strut, and you use less wire, and don't have to route all behind the dash and stuff. Just my common-sense approach I guess. GD Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 30, 2006 Share Posted October 30, 2006 Probably the other two wires in the 4 prong plug are the inhibitor wires that prevent starting in anything but park and neutral. GD Quote Link to comment Share on other sites More sharing options...
hatchsub Posted October 30, 2006 Author Share Posted October 30, 2006 so ur saying i should jump the other two together so that it will start? And about the drilling i thought about that myself and might just do that even though i dont like the idea of exposing new metal on these cars. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 30, 2006 Share Posted October 30, 2006 even though i dont like the idea of exposing new metal on these cars. Oh yeah - if it's going to cause rust - by all means ignore me completely. I don't have to deal with that, so do as you must. GD Quote Link to comment Share on other sites More sharing options...
