ogiesdad Posted October 30, 2006 Share Posted October 30, 2006 A month into owning the new car, and the only problem left is the control module is stuck in the dash position. I've tried pushing the other buttons, which light up but don't change, and the dash button doesn't pop back out. Is there a simple solution for this, like drilling a small hole in the button and "helping" it back out, or should I just plan on changing the module--I've already found the link for that searching the forum. Thanks. Link to comment Share on other sites More sharing options...
tcspeer Posted October 30, 2006 Share Posted October 30, 2006 You might try elc. spray cleaner from Radio Shack, just make sure you get the one that says safe to use on plactic. My buttons got sticky from drinks spilling on them and this worked on mine, but yours may be just broke. ogiesdad said: A month into owning the new car, and the only problem left is the control module is stuck in the dash position. I've tried pushing the other buttons, which light up but don't change, and the dash button doesn't pop back out. Is there a simple solution for this, like drilling a small hole in the button and "helping" it back out, or should I just plan on changing the module--I've already found the link for that searching the forum. Thanks. Link to comment Share on other sites More sharing options...
brus brother Posted October 30, 2006 Share Posted October 30, 2006 Distant memory of my 90 Loyale was that the buttons were vacuum related. On the 90 Loyale I had somehow disconnected a small diameter (same as windshield washer hose size) vacuum hose in the engine compartment on the passenger side just in front of the windshield. I can't remember if this stopped the buttons from working as you described or if the operation of the unit become non-functional until I reconnected the hose. Link to comment Share on other sites More sharing options...
Cougar Posted October 30, 2006 Share Posted October 30, 2006 I would try using a small flat bladed screwdriver and see if you can pry along the side of the button to pop it back out. Once it is out you may try and see if you can use a light oil on the latching area to see if that helps free the movement up. Link to comment Share on other sites More sharing options...
lmdew Posted October 30, 2006 Share Posted October 30, 2006 I have 3 good used units. $40+shipping. Lmdew@hotmail.com Link to comment Share on other sites More sharing options...
msmithmmx Posted October 30, 2006 Share Posted October 30, 2006 40 plus shipping is way to much, keep an eye out on Ebay for a week or 2. Link to comment Share on other sites More sharing options...
mjreilly Posted October 30, 2006 Share Posted October 30, 2006 The position of the climate buttons pretty much guarantees that they get splashed with whatever you put in the cup holders. Cleaning sounds like a good option to me. Link to comment Share on other sites More sharing options...
ogiesdad Posted October 31, 2006 Author Share Posted October 31, 2006 I doused the buttons such as I could with contact cleaner--now they punch up like they should, but the air's still coming out the dash outlets. I can imagine the previous owners being careless with the cupholders (there were paint stains on the seats--fortunately latex). If I need to, I can get another module locally, was hoping for an easier fix, though. Any other ideas? Link to comment Share on other sites More sharing options...
brus brother Posted October 31, 2006 Share Posted October 31, 2006 Did you take the module out to clean it, check wiring harness, caress, cajole, plead, wiggle, tap it gently with the heel of your shoe? You can always get a replacement but... is there a board member that could help with checking the harness i.e. jump it and make sure that it's not other than a bad switch module?? Cougar? Chief Tim? Nipper? Car 54 where are you? ogiesdad said: I doused the buttons such as I could with contact cleaner--now they punch up like they should, but the air's still coming out the dash outlets. I can imagine the previous owners being careless with the cupholders (there were paint stains on the seats--fortunately latex). If I need to, I can get another module locally, was hoping for an easier fix, though. Any other ideas? Link to comment Share on other sites More sharing options...
ShawnW Posted October 31, 2006 Share Posted October 31, 2006 brus brother said: Distant memory of my 90 Loyale was that the buttons were vacuum related. On the 90 Loyale I had somehow disconnected a small diameter (same as windshield washer hose size) vacuum hose in the engine compartment on the passenger side just in front of the windshield.I can't remember if this stopped the buttons from working as you described or if the operation of the unit become non-functional until I reconnected the hose. The legacy is not vac operated. Link to comment Share on other sites More sharing options...
ShawnW Posted October 31, 2006 Share Posted October 31, 2006 ogiesdad said: I doused the buttons such as I could with contact cleaner--now they punch up like they should, but the air's still coming out the dash outlets. I can imagine the previous owners being careless with the cupholders (there were paint stains on the seats--fortunately latex). If I need to, I can get another module locally, was hoping for an easier fix, though. Any other ideas? Honestly thats a really easy fix (getting a different one). While you are doing it get 3 new climate control bulbs from the dealer and put them in so you won't be back taking this apart soon. Link to comment Share on other sites More sharing options...
Manarius Posted October 31, 2006 Share Posted October 31, 2006 Under the dash, in the middle, there's a housing with a lever on the outside. These things have a tendency of getting stuck and causing your problem. Wish I could be more specific, but I've never had the problem so I can't be exact, but your problem resembles that. Link to comment Share on other sites More sharing options...
