November 1, 200619 yr Ok, my budy recently had a rear main bearing go out in his old motor, So we pulled the motor out of my camo brat, the one that had the dual carbs. Anyway i was a bit shocked when i removed the exhuast from the brat motor. My question is, what are these? Whats with the wall seperating the ports? Notice the shape of the port and the starnge stud offset?, the exhuast flange from the wagon don't fit these heads? ~CHIM~
November 1, 200619 yr i read about this some where, i thought it was a jdm only thing this rocks my world
November 1, 200619 yr What year is that engine or do you not know? EA81 or EA71? Two possibilities - either they are the older small valve heads use in pre-83 EA81's. Or they are dual-carb heads with reversed valve oreintation. Basically the intake and exhaust valves are reversed like the EA82's all were. That would make it a JDM engine as we didn't get those here except as import engines. The heads and the cam are different being the valves are reversed. The JDM dual carb engine was 108 HP in stock form - did you notice if it had a butt-load of power? All the EA81 heads have that wall, it's just up in there further on all the post-82 large valve's I happen to have here to look at right now. I don't have any small-valve heads to look at. Was the power steering a retro-fit to the Brat? GD
November 1, 200619 yr Author What year is that engine or do you not know? EA81 or EA71? Two possibilities - either they are the older small valve heads use in pre-83 EA81's. Or they are dual-carb heads with reversed valve oreintation. Basically the intake and exhaust valves are reversed like the EA82's all were. That would make it a JDM engine as we didn't get those here except as import engines. The heads and the cam are different being the valves are reversed. The JDM dual carb engine was 108 HP in stock form - did you notice if it had a butt-load of power? All the EA81 heads have that wall, it's just up in there further on all the post-82 large valve's I happen to have here to look at right now. I don't have any small-valve heads to look at. Was the power steering a retro-fit to the Brat? GD yeh, when the dual carbs where still on it it had more power than my ported motor with the weber, not sure what year it came out of, yes it's an EA-81 1800, out of all the motor's/heads i have seen none looked like this. ~CHIM~
November 1, 200619 yr Author Those look like PS lines below the head. GD oh yeh, my bad this pic. was taken after we put the motor in the wagon, all the holes are present for mounting the pump tho.
November 1, 200619 yr Those exhaust ports look just like my dual carb EA81's. You have a wicked motor there mate. Fix that stupid small exhaust. Put a single big weber or the dual carbs on it. And She'll fly. That said, I am putting a EJ22 in my car. But I won't be selling my EA81dc, thats for a later project.
November 1, 200619 yr Yeah - that engine is worth a LOT. I wouldn't be giving it away. Definately a collectors item in the US. GD
November 1, 200619 yr Not only are those heads rare but the cam and pushrods are just as much.Anyone know if that engine has higher compression pistons stock?I know that the domes are a bit smaller.
November 1, 200619 yr Not only are those heads rare but the cam and pushrods are just as much.Anyone know if that engine has higher compression pistons stock?I know that the domes are a bit smaller. Yes - it's 9.5:1 stock GD
November 2, 200619 yr They are rare in Australia too. I've only talked to 3 people on AUSubaru that have the engine. Plenty seem to have the manifolds. It's sad, many might have gone to the crusher with only the manifolds removed Keep the engine, do it up, and it will rock. Mine is having trouble getting over 6.5K rpm at the moment, and needs a full rebuild. But it still woops an EA82 with a weber by far!
