jaysterl Posted November 1, 2006 Share Posted November 1, 2006 Somewhat fustrated newbe here, can't seem to fix low idle problem at cold start up. Idle speed around 200 - non existant until egine warms up. AC compressor will not kick on until idle speed comes up. Background ; 93 Loyale EA82 SPFI D-check code 24- Idle Air Control , check engine light goes out on next startup after egine warmed up. I visually checked vacuum hoses for loose or leaking. Removed and cleaned AIC, tested solinoid function. Checked egine grounding. cleaned MAF sensor. What else should I be looking for? Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 1, 2006 Share Posted November 1, 2006 Verify that the TPS idle switch is working. The top two pins (A and should show continuity with the throttle closed. Also check the intermediate connector between the manifold harness and the body harness - the two big round connectors. Maybe just something corroded. GD Quote Link to comment Share on other sites More sharing options...
jaysterl Posted November 1, 2006 Author Share Posted November 1, 2006 Ok I checked TSP idle switch cold with throttle closed and had continuity, then I read in Haynes that this should be checked at normal operating temp. Checked again warm and no continuity between A and B pins. Now if I can only figure out how to get to the bottom adjustment screw, the AC compressor is right in the way. Quote Link to comment Share on other sites More sharing options...
nvexplorer Posted November 2, 2006 Share Posted November 2, 2006 That problem also has to do with your Idle Air Control Valve. My 93 loyale either has a really high, talking up to 3000 rpm some days, or really low, won't stay running without me feathering the gas. Just like you, my check engine light comes on when these symptoms happen. I took the valve actuator off and fiddled around with the valve once and it kept it from happening for a while. I guess these things get stuck sometimes or just need a good cleaning. Maybe taking the valve out and actually cleaning/lubing it may clear up the problem. The IAC actuator is the cylinder coming off of the passenger side of the intake, right under the air bypass hose, the one going to the IAC valve. It's held on by two screws that can be a bit of a pain to take off because you have to get the screwdriver around a bunch of stuff. There is no gasket between the valve and actuator, so don't worry about anything falling off when you remove it. It is the one with the round black connector. Took me a couple minutes to figure out how to get the connector appart. You have to lift the plastic tab and pull the connector appart at the same time. A flat head screw driver has been my best friend for that. The first time I tried to get it working I just moved the valve manually and it did loosen up a bit and I didn't have that problem for a while. Maybe some carb cleaner or something would help. Maybe spraying some down the bypass tube and moving the valve could help to clean things up. I hope this helps and that someone else can add to this. Quote Link to comment Share on other sites More sharing options...
daeron Posted November 2, 2006 Share Posted November 2, 2006 sounds like the sort of thing the SeaFoam Deep Creep penetrating lube works really good at cleaning out... I am also finding that fishing reel oil, specifically Quantum Hot Sauce, is an EXCELLENT heavier penetrating oil....... but VERY expensive. no further tips, though.. I am paying attention to this thread for tweaks to be done on my own vehicle, however :- ) Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 2, 2006 Share Posted November 2, 2006 I hope this helps and that someone else can add to this. He said he already cleaned it - he just mixed up the acronym in his first thread. Thus I sugested the idle switch in the TPS. You'll probably have to remove the AC and alternator bracket, and when you put it back together it would be wise to leave the bottom screw out of the picture for the TPS. GD Quote Link to comment Share on other sites More sharing options...
nvexplorer Posted November 2, 2006 Share Posted November 2, 2006 Haha sorry. Maybe my post will help someone else someday. Quote Link to comment Share on other sites More sharing options...
RSM Posted December 14, 2009 Share Posted December 14, 2009 (edited) Belated post to assist others experiencing Code 24: Vehicle: 1990 Subaru Loyale, 1.8L, SPFI (TBI), normal aspiration, 5 spd. MT, EA82, 237,000 miles. Symptoms: Very low idle speed (250-400) on cold start when ambient temp. less than 40 deg.F. and engine was ambient cold. CEL "ON" and computer flashing Code 24 (Idle Air Controller/Idle Speed Controller). After engine warmed up, idle speed suddenly increased to normal fast idle and CEL still "ON". However if keyed engine "OFF" and restart... everything was normal (no CEL), with normal idle speed. Perfectly normal operation at warmer ambient temperatures and on subsequent starts when the engine was warm. Process: Went through the gamut of testing IAC/ISC resistances; observing IAC/ISC function when external 9 volts applied to terminals; measuring resistance between ISC connector and ECU; replacing ECU and IAC/ISC (with used but good units); checking TPS & engine temp. sensor (ECU);cleaned all contacts; and looked for worn cable harness spots. ALL appeared or tested OK but starting problem persisted at ambient temps below 40 deg when the engine was cold. Eureka moment: Discovered when engine cold, showing Code 24, CEL "on", and idle speed low, that manipulating (bending) the engine cable harness between the intake manifold and distributor, the RPM's would momentarily increase and CEL would cycle "OFF" Further testing determined that the white ISC wire (black outer casing), which also has an ungrounded wire shielding or reinforcing braid layer, had intermittent continuity between the connector on the left side of the engine compartment (behind & below battery) and the IAC/ISC connector. Attempting to pinpoint the trouble point proved frustrating and futile. Action: Opened entire engine cable harness from IAC/ISC to fender wall connector, exposing all wires. The IAC/ISC wire (white, shielded, black covered) ran generally in the center of the other wires and was not cut or abraded. Replaced the entire length of the IAC/ISC white wire, between IAC/ISC connector and fender wall connector, with insulated but unshielded wire. Tested for good continuity, re-wrapped wires in protective wire loom, and reconnected all connections and grounds. Further testing of the removed section of wire revealed a point of intermittent continuity at approx. a third of its length from the ISC connector. Again, no apparent cuts or abrasion, and the harness section, filled with other wires, has no apparent stresses applied during normal operation other than heating and cooling since it is above the engine. Following wire replacement, engine starting and operation, even when cold (below 40 degF.) proved perfectly, and satisfyingly normal. Conclusion: Wire probably had a latent, hidden, manufacturing defect leading to an internal break that separated (lost continuity) when the wire was cold and the center conductor expanded enough to make connection when it was warm/hot. Possibly contributing to this defect was the braided shield, reinforcing layer, not seen on other wires in the harness. When heated,the outer metal, braided layer would expand (lengthen) first, thus pulling tension on the center conductor. This repeated action over 20 years may have facilitated the failure at a weak point in the center conductor. Note: Earlier tests of wire continuity did not reveal the problem since they were conducted at temps above 40 deg. and the "break" was intermittent. While one should start with the "obvious" IAC/ISC failure troubleshooting, after you've gone through all the "obvious" potential failure points, don't forget the "obscure", potential failures. It may save some head banging frustration or sending an old Subie to the grave prematurely. There is also a black w/ white stripe wire tht goes a short distance in the harness before connecting to multiple devices. If good continuity to that point the rest is probably OK or you would see multiple error codes thrown. Old Subies are fun to drive when they're well maintained and "ticking" like they're supposed to, and they are great "trainers". This car is older than my daughter, who drives it "relentlessly". Hope this helps someone with a similar, frustrating problem. Edited December 14, 2009 by RSM Clarity of evice names. Quote Link to comment Share on other sites More sharing options...
Frank B Posted December 14, 2009 Share Posted December 14, 2009 Ok I checked TSP idle switch cold with throttle closed and had continuity, then I read in Haynes that this should be checked at normal operating temp. Checked again warm and no continuity between A and B pins.Now if I can only figure out how to get to the bottom adjustment screw, the AC compressor is right in the way. You need these in your tool box, Still a pain, but it works. Sometimes , if there's room, you can take a phillips bit for a drill, in a small socket, on a 1/4" drive rachet too. Quote Link to comment Share on other sites More sharing options...
