DHDH Posted November 2, 2006 Share Posted November 2, 2006 I have an '89 DL 4x4 with bad front CV joints on both sides. I'm thinking about removing the whole half axle shafts from both sides and trying to drive it with the 4 wheel drive engaged...use it as a rear wheel drive until I can replace the axle shafts. Has anyone done this, or does anyone know if it is possible to run it this way? Thanks all. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 2, 2006 Share Posted November 2, 2006 Sure - works just fine if you use only the stub from the bad axle. Getting the axles apart is more work than replacing them tho. GD Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted November 2, 2006 Share Posted November 2, 2006 Drive it untill the axel blows, pull out the pieces, and run it rwd Quote Link to comment Share on other sites More sharing options...
Durania Posted November 2, 2006 Share Posted November 2, 2006 By doing this, you must post us a picture on here of you roasting them back tires. Quote Link to comment Share on other sites More sharing options...
jeffast Posted November 2, 2006 Share Posted November 2, 2006 By doing this, you must post us a picture on here of you roasting them back tires. i'll have what he's having Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 2, 2006 Share Posted November 2, 2006 Drive it untill the axel blows, pull out the pieces, and run it rwd Not very wise, as they can come apart. A flailing driveshaft can cause pretty gnarly damage. Beleive me, I've had it happen 3 times now - 4 if you count that one rear axle.... it made such a racket I pulled over and took it out though. GD Quote Link to comment Share on other sites More sharing options...
Phizinza Posted November 2, 2006 Share Posted November 2, 2006 Quick search turned up this, which I remember posting too. http://www.ultimatesubaru.org/forum/showthread.php?t=63065&highlight=rwd+conversion Pretty much everything was covered I think. Anyway, Welcome to the forum. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 2, 2006 Share Posted November 2, 2006 how bad are these axles, are the Subaru (the originals) and do you drive off road? i've put 50,000+ miles on broken boot, clicking axles. the Subaru axles are solid and i've never had one fail. i've rarely seen them fail on the groups either, and those times are usually from guys with lifter/offroaded vehicles. i never replace mine until 'im pulling the axle out for something else. i have two broken in the rear and one up front now....so what, i know they won't fail and i'm definitely not messing with them any time soon. i'll get to it in a year or so. i'd leave them there. if they are clicking really bad you can hand pack some grease in there to quiet them down. Quote Link to comment Share on other sites More sharing options...
DHDH Posted November 2, 2006 Author Share Posted November 2, 2006 These are pretty bad. I've gone through a couple of sets of replacements and this is about the worst they have gotten. They click sometimes driving straight, and I get this violent steering wheel shaking. I don't 4 wheel it, though live on a dirt road. The wagon has 353 K on it though. I have packed grease into the torn boots before, but not on these. May be worth a try again. Maybe I won't pull the axle shafts, but I like Durania 717's idea of roasting them back tires! Anyway 353 k -and still a good ride! Quote Link to comment Share on other sites More sharing options...
Durania Posted November 2, 2006 Share Posted November 2, 2006 Maybe I won't pull the axle shafts, but I like Durania 717's idea of roasting them back tires! Its your civic duty to do that. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 2, 2006 Share Posted November 2, 2006 if they aren't Subaru axles i wouldn't trust them. i've seen aftermarkets blow to pieces with very little stress. but like i've said...i've put 50,000+ miles on clicking CV's on original Subaru axles. if they start clicking while driving straight that's when i start planning on replacing them...usually with a brake job or something else requiring similar work. the two birds with one stone thing. but if they aren't Subaru or MWE i'd be looking to get them out quick. when you replace them, get used Subaru axles or rebuilds from MWE..or new from subaru if you like giving away your wallet. aftermarkets suck, seen them explode. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 2, 2006 Share Posted November 2, 2006 GCK Ftw. They do not suck. Better than the OEM ones possibly. GD Quote Link to comment Share on other sites More sharing options...
