reiersgaard Posted November 3, 2006 Share Posted November 3, 2006 Well, I did a search and can't seem to find anything similar to the problem i am having. I have an '82 EA81 and the defrost is only working on the drivers side. I did do an engine swap, so I could have not connected something right. However, I don't remember it ever working. Thanks for any help. Link to comment Share on other sites More sharing options...
scrap487 Posted November 3, 2006 Share Posted November 3, 2006 Well, I did a search and can't seem to find anything similar to the problem i am having. I have an '82 EA81 and the defrost is only working on the drivers side. I did do an engine swap, so I could have not connected something right. However, I don't remember it ever working. Thanks for any help. probably mice nest in the passanger side vent. any nasty smells in the car? if so a couple mice probably died in your vents. Link to comment Share on other sites More sharing options...
reiersgaard Posted November 3, 2006 Author Share Posted November 3, 2006 No smells. How would one clear out those vents? Link to comment Share on other sites More sharing options...
jeffast Posted November 3, 2006 Share Posted November 3, 2006 you could try compressed air but i think your going to end up pulling the dash to get to the heat vent plumbing Link to comment Share on other sites More sharing options...
Virrdog Posted November 4, 2006 Share Posted November 4, 2006 I had this exact same problem. Mice had made a nest. They also busted out the vent tubing in spots throughout the dash. I was fiberglassing forever and continually finding broken spots. Link to comment Share on other sites More sharing options...
scrap487 Posted November 4, 2006 Share Posted November 4, 2006 if your getting air to one side or the other you may not have to pull the dash. pull the vent peice that goes from the center heatercore section of the vent system to the passanger side defroster and clear out what you can, while you're at it you might as well pull the portion coming from the blower motor while you're at it and clean that out if it needs it. You will need to remove the plastic shelf part of the dash beneath the glovebox to get to those. If those are clear... well come back, you may be looking at pull the dash but maybe i'll think of something else till then. it took me 2 days to pull the dash in my 84 wagon, although that has a bit more wiring i believe than an 82 but all the same, its a b****. Link to comment Share on other sites More sharing options...
82bratavenger Posted November 4, 2006 Share Posted November 4, 2006 I recently pulled the venting of my 82 brat and from the blower duct I was able to run a small shop vac hose up into the passage and suck most all of the stuff out. After that I blew it from the other side with shop air as the vac was running in the duct. It works great now. Darn rodents. Link to comment Share on other sites More sharing options...
reiersgaard Posted November 4, 2006 Author Share Posted November 4, 2006 Thanks alot for the help, I will try it cleaning it out on sunday. I noticed last night that I was getting air to blow but it was directed at the floor on the far right side. Link to comment Share on other sites More sharing options...
