WoodsWagon Posted November 5, 2006 Share Posted November 5, 2006 My mom got impatient and decided to remove the bug deflector off the front of the Legacy we just bought. Didn't like it, so she tried pulling it off. She coulda lifted the hood, it was unlatched, and seen the two big phillips screws holding it on, but no, so now it's cracked. The two cracks run towards each other, one from each side. I'd like to save the bug shield. If I drill holes to terminate the cracks, what glue should I use to seal the cracks back together? I think it's ABS plastic, I dunno, its smoked plastic. Identicle to this: Link to comment Share on other sites More sharing options...
porcupine73 Posted November 5, 2006 Share Posted November 5, 2006 Well it would probably be worth a shot to save it! If you can see the cracks I might try a clear or amber epoxy. Otherwise JB weld might work that stuff is pretty good. Link to comment Share on other sites More sharing options...
Subie Gal Posted November 5, 2006 Share Posted November 5, 2006 epoxy will probably work once it's cracked, they're pretty much ruined. good thing is a new bug guard is only $50-60... Jamie Link to comment Share on other sites More sharing options...
gbhrps Posted November 6, 2006 Share Posted November 6, 2006 I believe that the air deflector is made out of acrylic plastic, and can be glued using an acrylic plastic glue that is very watery. Home and industrial glass companies (those local companies that can custom cut you a mirror for your bathroom, or cut and bevel edge a glass top for your coffee table) also work a great deal with acrylic to make pamphlet holders and signs. I'd take it to one of them and see if they wouldn't put a bead of glue on the inside of each crack so that it doesn't show. The nice thing about the glue is that its almost instantaneous. It shouldn't cost you much, and most likely they'll have an employee do it for free, for all of the time it'll take. Good Luck! Link to comment Share on other sites More sharing options...
porcupine73 Posted November 6, 2006 Share Posted November 6, 2006 Good point gbhrps, I recall that watery glue from working with acrylic plastic in shop class in high school, that glue worked great and you could not see the seam at all after gluing, especially if you buffed it a little bit afterwards. Link to comment Share on other sites More sharing options...
WoodsWagon Posted November 6, 2006 Author Share Posted November 6, 2006 Great suggestion. I'll see if I can find some. Link to comment Share on other sites More sharing options...
mheilmann Posted November 6, 2006 Share Posted November 6, 2006 I had a problem with mine (97 Legacy) driving in the South Dakota "breeze" - the sides "flopped" against the paint (had the little tape thingies on) 'cause the plastic clips kept slipping off the hood. Bought some small (4-48) screws and a tap and screwed the clips to the hood. No more flopping. Link to comment Share on other sites More sharing options...
