Yeah it's stock. But as weird as it is, I check the fuses this morning and not one was burn. And the radio and the CD wasn't working. I just got back from my errants and now it work!?!? As much I love my car, I always get little things like that! There's always something...
What kind of errants did you do ?
Just in case it happens to me...
errants? lol do u mean parents?
Errands as in running some errands. "2 a : a short trip taken to attend to some business often for another <was on an errand for his mother> b : the object or purpose of such a trip "
What would you guys do without us Canadians? :cool:
The answer is 2b. :)
I was getting some stuff for my girlfriend. But it did it again this morning! The radio was playing and then... Nothing! But when I closed the door it start playing again. Must be a loose connection somewhere...
If the lights and digits are on in the radio, then an external wiring problem is pretty much out of the question, unless you are using an aftermarket amp.
The chances of all speaker connections going bad at once are very, very limited.
My money is on an internal failure, as a single cold solder joint can in the amp section can cause this problem.
Or, the plug on the back of your unit, so to speak, is not all the way on.
