Everything New - Gas Mileage Got WORSE
Okay here's the dilly-yo (97 OBW 5SPD 136,000 miles):
New clutch
New head gaskets
New timing belt/pulleys
New water pump
New oil pump
New cam/crank seals
New front wheel bearings
All together $4000
Prior to the maintenance I was getting a solid 25-26.5 MPG, every tank - I check every tank religiously. As all my car is used for is back-and-forth to work (90miles/day).
First two tanks after everything was replaced, 20 and 23 MPG. I was hoping to bump it up a bit with all of this, not go down!!!
Any suggestions - I have no CEL. What would cause a sudden significant drop like this? Since they had to work on all sides of the engine, it was pulled from the vehicle.
The battery was probably disconected when the engine work was done. This will erase what the car's computer has "learned" and will reduce power and efficiency untill it relearns the engine's charactaristics.
Drive the car normaly, and it will come back. The carbon build up in the engine may have raised compression, leading to higher efficiency.
There are certain driving patterns that will speed up the relearning process.
Maybe since you got the work done, you've been hopped up with excitement and been driving more aggressively....:headbang:
matt
This was my first thought too :) as silly as it sounds. With such a small difference in mileage over a short test period it could very easily be 100% driver.
Thats not significant. Give the computer a month to relearn your driving. Also the change of seasons will affect gas mileage, along with seasonal fuel changes. There is nothing on that list that should affect gas mileage.
Check your tire pressures.
nipper
Thanks for all the input, I will give an update in a couple weeks. When every single tank for 7-8 months reads 25-26.5 MPG, 2-3MPG (10%) is significant.
But I will say the new clutch engagement did take a little gettin' used too. I had some O2 sensors laying around (brand new) so I will probably do that over the coming holiday weekend as well.
I was hoping to see numbers approaching 30 all said and done.
Yeah, everyone covered most of the changes. I'll just add the new pumps and bearings might be working themselves in and might cause a slight parasitic loss of power.
Give it a couple of more tanks and you might start seeing your old mileage numbers. And then they should go higher when they stop pumping winter gas. :-\
