EA82T head bolts - Reusable?
Are the head bolts on a EA82T Reusable? or are they Torque to Yeild?
Oh and where is a good & cheap place to get Head Gasket Sets? or Should I just get individual Head gaskets. (I'm planning on building a High compression MPFI (minus turbo) with a SPFI short block.)
EA82 head bolts are reusable; they are not torque-to-yield. Regarding head gaskets, by "where" do you mean dealer-vs-auto parts store, or brand? Consensus seems to be either dealer/OEM or FELPRO. NAPA-branded seems to get panned often, and almost everyone offering an opinion swears by dealer intake and exhaust gaskets (others being inferior design/construction and failure-prone). I would go with the gasket set, as there are SO many little gaskets involved. Also, there is an oil passage gaket ("o-ring") between the head and cam-carrier that needs to be the dealer-style metal-reinforced o-ring rather than a standard rubber o-ring.
The only caveat I would add to the bolt-reusing bit is that if you know the engine they came out of got totally fried from overheating, I would be scared to use them for fear of the heat changing the properties of the metal. I'm not a metallurgist so I don't have a clue if that's actually possible, but I'd rather not take a chance.
Most tempering of steel occurs at around 500 degrees and up - oil and salt bath tempering can range from around 475 degrees to over 1000 degrees and higher. So I wouldn't expect any problems with reusing them. I've reused plenty that were overheated. It shouldn't damage the properties of the bolts any. If you got the engine hot enough to de-temper the steel in the bolts you would also de-temper the piston rings, and the engine would seize :eek:
Thanks for the info guys!
So should I torque them to factory spec - or is over torquing common a practice?
I know with Toyota Supra Motors (7MGE & 7MGTE - 3.0L I-6 motor) the factory spec is too low and its a common pratice to over torque them by 15-20% since they are know for head gasket failures.
