dixracing Posted November 11, 2006 Share Posted November 11, 2006 why is it so difficult to get one of these? .........holy moly. may the gurus of soobies please enlighten me? stories from hell? or close to? thanks.... Link to comment Share on other sites More sharing options...
Qman Posted November 11, 2006 Share Posted November 11, 2006 why is it so difficult to get one of these? .........holy moly. may the gurus of soobies please enlighten me? stories from hell? or close to? thanks.... Never had a problem getting them before. Where are you trying to find one? Do you have any driveline shops in your area? You could always go to the PaP in Oly and pull a couple of used ones. Link to comment Share on other sites More sharing options...
dixracing Posted November 12, 2006 Author Share Posted November 12, 2006 well i believe info is power ......so i am collecting info.....tried napa and shucks pro shop......lol........tried subaru dealer.....lists for 200.00......dream on.....my whole soobie didn't cost that..... :D ...... Link to comment Share on other sites More sharing options...
pyromanic Posted November 13, 2006 Share Posted November 13, 2006 I don't know why, but when I did my 5sp DR swap from auto and then the lift, I looked at that bearing and said to my self, "bet that's gonna be hard to find if I ever have to replace it." Personally, I don't care to much for the idea of JY bearings, but that's just me. I care less for the idea of $200 bearings though!! Fortunately I don't need one right now, which is surprising to me, as the one I'm running has a couple hundred thou on it. I think when either U joints or carrier bearing bite the dust, I'll just switch to custom one piece drive line. Make sense? Pyro Link to comment Share on other sites More sharing options...
dixracing Posted November 13, 2006 Author Share Posted November 13, 2006 i thought about a one peice .....but with the 8" lift i think the driveline would be hanging kinda low .......wouldn't it? Link to comment Share on other sites More sharing options...
pyromanic Posted November 13, 2006 Share Posted November 13, 2006 i thought about a one peice .....but with the 8" lift i think the driveline would be hanging kinda low .......wouldn't it? Yea, that sounds right to me. Steep angles would maybe wear out the joints too fast also, correct? I'm only lifted 3 inches, so might not be a problem. Truth is, I don't know. But before I'd spend two bill on a new carrier, think I'll look into one piece custom drive line. (unless somebody advises against it that is) PS. I just brought home a wire feed MIG welder!!!!!!!! 90 bucks and a beat up Ruger 10/22 I didn't use anymore! Woohooo!!!!!!!!!!!!!!!!! It's not a Lincoln, but at that price (everything works) I'm happy! Pyro Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted November 13, 2006 Share Posted November 13, 2006 Ive always used the original that was on the car, just dropped down some Link to comment Share on other sites More sharing options...
Numbchux Posted November 13, 2006 Share Posted November 13, 2006 i thought about a one peice .....but with the 8" lift i think the driveline would be hanging kinda low .......wouldn't it? I don't understand how it could matter. if you're not dropping the carrier bearing down that far anyway, you're going to toast those u-joints backing out of the driveway. I'd go one-peice or junkyard. wouldn't even consider a new bearing. Link to comment Share on other sites More sharing options...
subyrally Posted November 14, 2006 Share Posted November 14, 2006 the suby dealer here told my that you cant replace em and that the drive shaft wasnt serviceable, on top of that, none of the shops in my area could get anything to match it . Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted November 14, 2006 Share Posted November 14, 2006 i would also say that a one peice would be better, stronger too.... Link to comment Share on other sites More sharing options...
dixracing Posted November 14, 2006 Author Share Posted November 14, 2006 hey guys ....thanks for the opinions......well i repaired the carrier mount,but it still makes noise when i wood it.....prolly killed the carrier ....i guess i'll limp for a bit til i decide what to do...... Link to comment Share on other sites More sharing options...
