oem protenza's.....almost wrecked.
Have any of you ever taking you Subaru's out on a track? It is suprising how far you can push it before it actually understeers. ////
Mr. Expert does not seem to be aware that the XT and H6 used the VTD drive system, which puts 55% of the torque to the rear by default. Most Gen III wagon drivers also put 1-2 psi more tire pressure in the front, which also helps balance the car.
If you watch the video at http://www.youtube.com/watch?v=eYKJIVajAIE you'll see there's little understeer evident - it's quite neutral.
The slight torque split combined with more tire pressure in the front end balances the car. That is great. So?
I'm an expert because I have some idea of how to control a car in a turn? Where is my merit badge?
I guess I should just make one sentence statements without demonstrating any knowledge about the subject.
Here is a link:http://www.youtube.com/watch?v=XJemif6bSCQ
Notice the mild understeer. This vehicle is actually accelerating in the turns.
The SVX has the VTD too, BTW.
Flames are for ricers. Lighten up:-p .
