rjohn Posted November 13, 2003 Share Posted November 13, 2003 My rear shocks deflate after the car is off. Could this be a control module issue or just leaks. they pump back up as soon as the engine is turn on. Robby in NC. Thanks Link to comment Share on other sites More sharing options...
DerFahrer Posted November 13, 2003 Share Posted November 13, 2003 They always lower a little when you turn the car off, to lower the step-in height... My XT does the same thing... How you can tell if your air suspension is leaking is if you start the car up and the compressor runs constantly, putting air into a strut that's always leaking it out... Or of course, if the car is slammed to the ground because you no longer have any seals Link to comment Share on other sites More sharing options...
rjohn Posted November 13, 2003 Author Share Posted November 13, 2003 Where is the compressor located? Robby Link to comment Share on other sites More sharing options...
alias20035 Posted November 14, 2003 Share Posted November 14, 2003 Quote Originally posted by rjohn Where is the compressor located? Robby In front of the driver's side front wheel. Pull back the fender liner to see it. Link to comment Share on other sites More sharing options...
