Hella 500 Install 1st gen
Yes, those are washers. Great stuff in salty winter!
The headlight has beam, and if you look closely you'll see a small vertical divsion behind which the white side marker lights hide.
The outer lamp, a separate unit, is normally off and flashes when the indicator stalk tells it to.
Worth a thousand words:
http://img.photobucket.com/albums/v684/Setright/Lights_on.jpg
Way cool! Why can't they do that kind of stuff over here?
I ferried a friends car to town to the Subie dealer, and then back after work. Outback wagon, so I got to experience the driving lights. THAT'S IT!, the next step on the deBrightonization of the 2000 is llights in the fascia nostrils. I couldn't believe how much better the lighting was.
