hi, new here.... from cold Norway :D
I'm having a problem with my legacy '90 with automatic transmission, the 4wd won't work, it worked just fine earlier but suddenly it stopped working, it's only the wheels in front that turn around now..... i did not hear a snap or something in the driveshaft or the lsd or what's it called.....
the strange thing is that it worked when i parked it, 40 mins later when i started up again it did not work any more
i have checked the fwd fuse, thats not the problem.....
hrmmm the snap is not a good thing.
DO your tires match and are they worn the same.
You dont use the FWD fuse unless there is aproblem with the AWD (like its binding) or the car has a flat or is towed.
Are you the original owner
How many Kilometers are on this car
Did you have any torque bind
nipper
(Nipper, there was NO snap ;) )
Oharaune, in the engine room, there is a slot for a FWD fuse. That must NOT be installed, it puts the gearbox into FWD only.
Check the regular fuse box and make sure the TCU fuse is okay.
As asked above, how many kilometers, how old is the gearbox oil, is the level okay?
