tranny swap underway...a few questions
Hey everyone. I dug into my car today and the autocraptic is out now. I also struggled to get the pedal assemble out and finally did by unbolting the steering column. Now for the questions...
1) i havent gotten a chance yet but it seems that only two holes (one on each side) out of the four on the manual crossmember line up with holes on my car. Is this what others who have done this swap have run into?
2) There is a cut ground wire on the top of the manual tranny thats going in. There was not one on the auto. Is this for my reverse lights and if so where should i run the new ground to? Just to the negative on the battery?
3) Is there an easier way of putting the new pedals in? I was just to damn tired after fighting with stuff today to go any farther and see if i could get them in.
Thanks for all your help!
1. You have to swap the radius rod plates as well - they are not the same from auto to manual, but they are the same from 4WD to 2WD manual. It simply won't bolt up at all without them. This is an EA81 specific deal - the EA82's are not like this at all, and there's VERY few people on this board that have done auto to manual on an EA81.
2. Ground is just from the tranny to the body. All the manual trans EA's have that. It goes right on the front of the "lip" for the spare tire shelf.
3. Nope - you pretty much always need to remove the column. Just undo the column from the u-joint in the engine bay and pull the whole thing out of the car. Makes it a lot easier to work.
Radius rode plates? Im not sure i know what these are.
Also as far as getting the car to start i understand that i have to jump the two wires but i noticed that there is a connector coming off of the clutch pedal. Could i wire this over to the starter wires on the inhibitor switch so that the car will only start with the clutch depressed?
the radius rods are the rods going from the control arms back to where the tranny crossmember mounts to. You have to swap those plates that they mount to because of fitment issues like you found out dealing with the crossmembers. It should be only like 3 bolts a side for those.
No - the inhibitor switch was in the old auto shifter. The wires from the ignition switch to the starter solenoid are interrupted by this switch, and you must jumper the two back together or it will not crank. The clutch switch is probably (almost certainly) for cruise control which I'm guessing the donor car had. It's also not a large enough switch to handle the crank circuit draw.
As caboob mentioned - three LARGE bolts each for the plates, and the radius rod nut itself. I don't think the rod's are different, just the plates.
ok thanks guys for the info. I was comparing crossmembers and one bolt on each side of the manual crossmember looks like it lines up with the auto crossmember. Im not sure if they are located in the same place as far as distance from the engine though. I was hoping to get this car finished this weekend..now im lucky if i get it done this week :( To top it all off one of the studs broke off in my head when i went to take the exhaust off and then two studs just unthreaded all together. So i have to redo it again.
ok just went down to the trannys and looked. The crossmember dont even begin to line up with eachother..they are not even close to the same location on the transmisions. This sucks. I have a want ad posted in the forum but ill put it here too.. in need the radius rod plates asap
Hey GD you wouldnt happen to know if the radius rods themselves are any diff between stick and auto would you? Just want to make sure i have everything i need for sure this time. :)
i hope not, im using ones from the auto in mine which i have converted....!
Seems fine.
ok thanks guys. Ill probably post some pics up of the conversion in 3-4 weeks. I gotta go back to school on sunday night and the car gets to sit on jackstands from now until i return for winter recess. Oh and i was able to get the pedal assembly in without removing the column..wasnt too bad actually.
One more thing..is there a special mount that keeps the shifter and linkage from falling down? the shifter and linkage is all on a pivot with bushings but its kinda floppy by itself. There is a rubber square at the back of it all ( behind the shifter). Did this used to be some way of securing it all? If so it looks as if i need one of these.
