rusty1 Posted November 19, 2006 Share Posted November 19, 2006 The lights that illuminate the right hand (tachometer, temp guage) side of the instrument cluster seem to need new bulbs. Is it difficult to access them? TIA Link to comment Share on other sites More sharing options...
rusty1 Posted November 19, 2006 Author Share Posted November 19, 2006 rusty1 said: The lights that illuminate the right hand (tachometer, temp guage) side of the instrument cluster seem to need new bulbs. Is it difficult to access them? TIA Correction : It's a 2000 Forester Link to comment Share on other sites More sharing options...
Setright Posted November 20, 2006 Share Posted November 20, 2006 Shouldn't be. Can you find two "hidden" screws on the underside of the dial cowl? Undo those and it should only be two clips holding the bottom of the cowl. Pull toward you. ONce that's off, you can see the screws holding the actual dashpod. Link to comment Share on other sites More sharing options...
ferret Posted November 20, 2006 Share Posted November 20, 2006 Attached .pdf Link to comment Share on other sites More sharing options...
rusty1 Posted November 20, 2006 Author Share Posted November 20, 2006 Thanks, ferret esp. Link to comment Share on other sites More sharing options...
