4x4_Welder Posted November 25, 2006 Share Posted November 25, 2006 In the process of slinging a new rear suspension under the Hatch, 2" lift via the torsion bars. I have heard of using Chevette shocks, but the mounts look all wrong. Is it possible to just drill new holes a couple inches down the shock mounts and use the stock shocks, or do I have to go with different shocks? I did a sarch, but maybe I just don't know how to search, I can never seem to dig anything up- Link to comment Share on other sites More sharing options...
GLCraig Posted November 25, 2006 Share Posted November 25, 2006 From what I remember reading about the chevelle shock, you need to drill the holes out and rotate the top mount in the bushing. I don't think you can simply re drill holes either. Behind the stock holes there are a couple of weld nuts that you would need to account for if you re drill and I don't think you can get behind that piece of sheet metal with new nuts. Also didn't someone come across a Ranch shock for the Jeep TJ that will work? Link to comment Share on other sites More sharing options...
carfreak85 Posted November 26, 2006 Share Posted November 26, 2006 Also didn't someone come across a Ranch shock for the Jeep TJ that will work? Yes and they work awesome!!! I've got a set and I'm VERY pleased with them so far. Link to comment Share on other sites More sharing options...
4x4_Welder Posted November 26, 2006 Author Share Posted November 26, 2006 Yes and they work awesome!!! I've got a set and I'm VERY pleased with them so far. Any particular year, front/rear? Or do you have a part number? Link to comment Share on other sites More sharing options...
