atf for 96 obw 111k 2.5 AT
I like amsoil syn atf, but you probably won't find it retail. You need at least 10 quarts if you're going to do a _complete_ change like pump and dump the torque converter, otherwise you need maybe 5-6 quarts for just a drain via drain plug and refill though that leaves you with like 40% old fluid left in there.
Mobil1 synthetic atf works nicely too and that's available retail (like at pepboys); just get a dexron III type product and you should be good to go.
