SoobGoob Posted November 26, 2006 Share Posted November 26, 2006 i changed the seal in my rearoutput thinking it was the cause of my leaky transmission. well turns out it wasnt but became a problem. its leaking and its a new seal. is it not pushed in far enough? or is it just a bad seal. trying to figure out asap any ideas will be appriciated Link to comment Share on other sites More sharing options...
beataru Posted November 27, 2006 Share Posted November 27, 2006 did you in any way possibly inadvertently... ahh speling sucks.... did you possibly slice or dice or dent the seal in anyway while installing it??? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 27, 2006 Share Posted November 27, 2006 This is the transmission from hades - seriously the thing leaks if you just stare at it in a way it doesn't find pleasing . Only potential for leak I could find is that rear output - it's definately comming from somewhere back there, and that seams the likely spot considering the splash coverage. Do this - spray the whole area down with brake cleaner to get all the mess off, then run it down the road a bit and check it right away. See if you can locate the leak better that way. It was raining, and messy when I looked at it so I could be wrong. Best to double check it. GD Link to comment Share on other sites More sharing options...
idosubaru Posted November 27, 2006 Share Posted November 27, 2006 listen to GD and clean it, verify where the leak is coming from. if it is the seal then carefully install a new seal keeping in mind the following: i'd install another one. take a look at a trans that isn't leaking and see how far the seal is seated so you don't push it too far or not enough. clean the sealing surfaces, grease the new seal and make sure it slides in slowly and straight. also important if you're having issues - check the driveshaft for any nicks or more importanly rust on the shaft. if it was a used one or ever pulled, swapped or sat for awhile it could have pitting or other issues on the machined part that rides in the seal. might want to hit it with a very fine grit wet sand paper (like for body work type stuff - 400 grit) if there are any bad spots on the shaft. Link to comment Share on other sites More sharing options...
SoobGoob Posted November 28, 2006 Author Share Posted November 28, 2006 ill look into that on the next dry day Link to comment Share on other sites More sharing options...
kayakertom Posted November 29, 2006 Share Posted November 29, 2006 Alec, On that trans there are 3 openings for switches, I know you found one that lacked a switch for the previous leak source - just checking that all three openings are blocked. Link to comment Share on other sites More sharing options...
SoobGoob Posted November 30, 2006 Author Share Posted November 30, 2006 it was missing the 4wd switch and a switch for lo? much have been just that year the LO switch was on the tranny. filled both those guess only the reverse lights are left Link to comment Share on other sites More sharing options...
