mikeshoup Posted November 28, 2006 Share Posted November 28, 2006 Okay, so I was driving to get the car registered, and learned what the problem is. I went WOT on the highway trying to pass a semi, and the car started to surge really bad. Then the ECS light came on and stayed on. Pulled over, it threw code 14, which is the MAF I believe. The car's on its third MAF from what I understand... I doubt its the MAF now (though, likely I guess). Anyone have suggestions? Could there be some other sensor that's throwing bad values, making the ECU think the MAF is bad? (I don't know, I'm grasping at thin air here!) Link to comment Share on other sites More sharing options...
jeffast Posted November 28, 2006 Share Posted November 28, 2006 from what i understand and what nos and phil told me they got the car with a stuck flapper style maf then went to an ea82 flapper maf that didn't work right i don't know what maf is on it now, i don't know how much help this is but it's what i know Link to comment Share on other sites More sharing options...
Ross Posted November 28, 2006 Share Posted November 28, 2006 Check the connector - the crimpy bits in them can get pryed apart so they dont grip the pins on the sensor properly... they are quite fussy with dirt/corrosion too. Link to comment Share on other sites More sharing options...
ShawnW Posted November 28, 2006 Share Posted November 28, 2006 I think I have a couple more used ones if you want to try them. PM to setup a meeting or maybe come to the snow thing this weekend and I could bring them along? Link to comment Share on other sites More sharing options...
subiemech85 Posted November 30, 2006 Share Posted November 30, 2006 14 Abnormal air flow meter signal Link to comment Share on other sites More sharing options...
mikeshoup Posted November 30, 2006 Author Share Posted November 30, 2006 Someone with access to an FSM covering the EA81 Turbo: What's the diagnostics page for code 14 (Abnormal MAF signal) say? Most specifically, the resistances between the terminals of the MAF? The 86 FSM for the EA82 Turbo say: Resistance between UB and Ground: 300ohm Resistance between UFIX and Ground: 200ohm Resistance between US and Ground: From 50 - 500 ohm. The MAF I have tests fine for the EA82 specs, but Noss seems to think the EA81 and EA82 MAFs are different, so I'd suspect those numbers should be different. Link to comment Share on other sites More sharing options...
mikeshoup Posted December 1, 2006 Author Share Posted December 1, 2006 Anyone with a Turbo FSM? C'mon here. Link to comment Share on other sites More sharing options...
carfreak85 Posted December 1, 2006 Share Posted December 1, 2006 Anyone with a Turbo FSM? C'mon here. From the EA81T wiring diagram supplement, May 1983: 1) Set key in switch in IG position. (Engine off) 2) Measure voltage between check connector II air flow meter Ufix (LY) + and ground (BR) - 3) Apporx 5V? I'll continue when you reply because its like 3 pages long and I have no scanner. Link to comment Share on other sites More sharing options...
mikeshoup Posted December 1, 2006 Author Share Posted December 1, 2006 I just want the part where it tells you to test the resistance of the MAF (says something about disconnect MAF terminal, measure resistance at blah). I want to see if the EA81T MAFs have the same resistance values as the EA82T MAFs. If so, then they're the same MAF, and my problem lies elsewhere. Link to comment Share on other sites More sharing options...
carfreak85 Posted December 1, 2006 Share Posted December 1, 2006 Disconnect air flow meter connector, and measure resistance between Us and GND of air flow meter... Approx 70 Ohm when flap is fully closed Between Ub and GND: Approx 300 Ohm Ufix and GND: Approx 200 Ohm Us and GND (With flap opened fully): Approx 50 OHM (With flap closed fully): 500 Ohm Looks to be identical to the EA82 MAF. Link to comment Share on other sites More sharing options...
mikeshoup Posted December 1, 2006 Author Share Posted December 1, 2006 Can you verify the last two for me? The MAFs I have read 50ohm between Us and G when flap is closed, and 500ohm between Us and G when flap is open which matches the 86FSM, though is opposite of what you say. Perhaps that's the problem, though I can't figure out how it would even run like that. Can you double check that the pins are the same? G is the leftmost, then Ub, then Ufix, then Us Link to comment Share on other sites More sharing options...
carfreak85 Posted December 1, 2006 Share Posted December 1, 2006 From left to right with the ECU plug pointing at me: G (UB), LY (UFIX), YR (US), GND (YL). Link to comment Share on other sites More sharing options...
subiemech85 Posted December 1, 2006 Share Posted December 1, 2006 Between Ub and GND: Approx 300 Ohm Ufix and GND: Approx 200 Ohm Us and GND (With flap opened fully): Approx 50 OHM (With flap closed fully): 500 Ohm G (UB) LY (UFIX) YR (US) GND (YL) THERE IS CONFLICTING INFO IN THE TEXT SEE CARDOMAIN PAGE 9 http://www.cardomain.com/ride/471729/9 Link to comment Share on other sites More sharing options...
mikeshoup Posted December 1, 2006 Author Share Posted December 1, 2006 Yeah, the numbers are the same, but backwards from the two MAFs I have. The MAFs I have are at 50ohm when closed, and 500ohm when open. I would think that the car wouldn't even run if this was the case though? Perhaps its a misprint? I dunno. I need to find an EA81T MAF though and rule it out before I go checking wiring. Link to comment Share on other sites More sharing options...
