Legacy777 Posted January 2, 2007 Share Posted January 2, 2007 I know some of you have already replied, but I'm going to move this to the old gen forum since the body style is the older gen cars. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 2, 2007 Share Posted January 2, 2007 Yeah - it's under the dash - attached to something up behind the fuse panel. Just scoot under there and you'll find it. Black square flasher module. GD Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted January 2, 2007 Share Posted January 2, 2007 is this the same thing that's bolted to the hood release cable bracket, or am I thinking of something else? (fuel pump control relay maybe?) /random thought -Dave Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 2, 2007 Share Posted January 2, 2007 Yeah - that's the FPCU. The flasher relay is further up undeneath. It's near the headlight relays IIRC, but don't take my word for it. Just look for something similar that will plug into your new one. GD Quote Link to comment Share on other sites More sharing options...
TheBush Posted January 3, 2007 Author Share Posted January 3, 2007 Yeah - that's the FPCU. The flasher relay is further up undeneath. It's near the headlight relays IIRC, but don't take my word for it. Just look for something similar that will plug into your new one. GD Im about to go clinically crazy if I don't find this.....anyone....i cant find it...ive never been more fruststrated in my life! P.S.- I do appreciate all the help from you guys tho, dont get it twisted. Quote Link to comment Share on other sites More sharing options...
daeron Posted January 3, 2007 Share Posted January 3, 2007 changing my flasher drew my first blood on my soob, and that was months after a timing belt change, brakes all around, rear bearings... the works. It is up there. Underneath the steering column, just to the driver's side of the car from the steering column, and above it. I had to turn my hazards on, and listen AND FEEL for the tick of the relay... since they are side by side that made it easy. I remember I had to unscrew a philips head that was holding the bracket in place, and i remember i did NOT bother screwing it back in. close your eyes, and feel your new relay. Now look up there with your hands and try to find two of those, side by side. If you think you have it, try unplugging and see if your lights still all come on. With the relay unplugged, they will NOT, so if you pull a plug and your lights no longer come on at ALL, then youve found it. get a stubby philips head and drop that thing down. As I recall, i had to unplug a few components just to get wires out of the way. This flasher is the ONE THING that Fuji Heavy Industries decided to screw us on. EVERYTHING else is easy, but this is a PITA to replace. Good luck. EDIT I *thought* this had come up recently.. heheh. Seriously, though, it is up there. try unplugging things one at a time, and trying your signals. If you unplug and they still light up, that was the wrong one. Plug back in, try again. there are only so many relays down there. By the way, the only way i have EVER been able to do ANY work under a dash is to move the seat ALL the way back, recline fully, and climb in headfirst. This is not fun, but its what has to be done. I did it in a day, but it took me all day, several "cooling off" breaks, and copious amounts of attitude adjustment. Good luck, again. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 3, 2007 Share Posted January 3, 2007 Big difference between the headlight relays and the flasher module. There is only a single flasher for the signals and hazards. But it is located near the relays. Relays are round and silver - flasher module is square and black plastic. GD Quote Link to comment Share on other sites More sharing options...
TheBush Posted January 3, 2007 Author Share Posted January 3, 2007 I will be trying this myself today later on....pray to god I can find it. Quote Link to comment Share on other sites More sharing options...
daeron Posted January 3, 2007 Share Posted January 3, 2007 http://www.ultimatesubaru.org/forum/showthread.php?t=40203&highlight=flasher http://www.ultimatesubaru.org/forum/showthread.php?t=11307&highlight=flasher i dont know if youve read those threads, but they seemed like they might help you a little?? i feel bad that i cant recall how to describe it more, because the more i think about it the more i recall getting more frustrated than I have ever been at a car when trying this myself. and believe me, i can get frustrated.... don't forget that even in broad daylight, you WILL need a good bright (but small) light up there, and a stubby philips head screwdriver. I can be repetitive, but i can be repetitive also. Quote Link to comment Share on other sites More sharing options...
TheBush Posted January 3, 2007 Author Share Posted January 3, 2007 I appreciate all the help, I really do. I am going to give this go today with a friend of mine...if we can't find it, Im giving up. This may be a stupid question, but sinec all 4 signals light up, they simply dont flash, is it possible that the WHOLE flasher relay is gone? Missing? Quote Link to comment Share on other sites More sharing options...
nipper Posted January 3, 2007 Share Posted January 3, 2007 I appreciate all the help, I really do. I am going to give this go today with a friend of mine...if we can't find it, Im giving up. This may be a stupid question, but sinec all 4 signals light up, they simply dont flash, is it possible that the WHOLE flasher relay is gone? Missing? As i have said before, if the flasher is no there, they lights won't come on. Have you checked all four bulbs, physically removed them and inspected them to make sure they are all good? nipper Quote Link to comment Share on other sites More sharing options...
TheBush Posted January 3, 2007 Author Share Posted January 3, 2007 Yep, all the bulbs have been checked. They are not the problem it seems. I will be checking for the flasher myself, with a friend in about 2 hrs or so. I will update you guys after I search for it. Quote Link to comment Share on other sites More sharing options...
TheBush Posted January 4, 2007 Author Share Posted January 4, 2007 We checked again...and guess what? No Luck. Stupid P.O.S.... Quote Link to comment Share on other sites More sharing options...
del Posted January 4, 2007 Share Posted January 4, 2007 TheBush figure it out? if you can bring the car buy durring daylight hours i am fairly sure i can find it. pm me a mesage if you still need help. del from yakivegas Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 4, 2007 Share Posted January 4, 2007 I am having a problem with my muffler bearings.They started going out after I replaced the regular blinker fluid with synthetic halogen blinker fluid.How do I replace them? BTW my cross-drilled brake lines work fantastic! Say What? According to the AutoZone website: Component Locations - Flasher On your 1991 Subaru Loyale, the Component Locations - Flasher is: Front seating area, driver side, under dash, above brake pedal, mounted in steering column support bracket As I Said... (Check Post Nº 2 on this Thread...) That´s the Place. Good Luck! Quote Link to comment Share on other sites More sharing options...
TheBush Posted January 4, 2007 Author Share Posted January 4, 2007 I private messaged del. Hopefully I can get this resolved....argg Quote Link to comment Share on other sites More sharing options...
nipper Posted January 4, 2007 Share Posted January 4, 2007 I private messaged del. Hopefully I can get this resolved....argg otherwise we teach him hand signals nipper Quote Link to comment Share on other sites More sharing options...
TheBush Posted January 4, 2007 Author Share Posted January 4, 2007 Heh. I already know the hand signals. However, I am 16. Waiting to take my drivers test to actually get my license, right now I only have my permit. I cant take the test without working flashers. I would also take it in my moms Subaru 2002 Imprezza, however the shifting is quite different, im very comfortable driving my car, and would prefer to drive my car. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 5, 2007 Share Posted January 5, 2007 otherwise we teach him hand signals nipper Quote Link to comment Share on other sites More sharing options...
Cougar Posted January 12, 2007 Share Posted January 12, 2007 In case you are still looking I checked my FSM for a '88 again. It shows the flasher to be next to a set of 4 relays. The area should be near the steering column as GD stated. It may be near the center of the dash also. Look for the four relays and the flasher should be above them if your model is like mine. Quote Link to comment Share on other sites More sharing options...
