nvexplorer Posted November 29, 2006 Share Posted November 29, 2006 Every time my car is really cold my turn signal switch starts acting up. After signaling a turn it normally pops back to the center position, where it isn't signaling right or left, but it totally skips the center position like it isn't there. It moves freely from right signal to the left. Oh yeah, this is on a 93 Loyale. Anybody else have this problem or know how I can fix it? Does it need to be cleaned and lubed and if so any suggestions? Thanks Link to comment Share on other sites More sharing options...
mellow65 Posted November 29, 2006 Share Posted November 29, 2006 sounds like you need to replace the turn signal assembly in the steering column Link to comment Share on other sites More sharing options...
nvexplorer Posted November 29, 2006 Author Share Posted November 29, 2006 sounds like you need to replace the turn signal assembly in the steering column Thanks for the reply. Its weird that it only does it when it is cold. happened this morning and still wasn't right so I left it signaling left (engine off so wasn't blinking) but later in the day when I came back and put it in the center it locked in place and has been fine. We'll see what happens tomorrow morning with a low of 15 F Link to comment Share on other sites More sharing options...
stephenw22 Posted December 1, 2006 Share Posted December 1, 2006 You need to go in and clean out the grease that's causing the problem. Those parts (from what I remember) are lubed up with a grease that gets really thick when it's cold. My '92 loyale has a similar problem at really low temps (-40). I just stop using my signal lights when it's that cold. Link to comment Share on other sites More sharing options...
nvexplorer Posted December 1, 2006 Author Share Posted December 1, 2006 That sounds about right. At least now I know that I'm not the only one that it happens to. What should I lube it with? I think I have some lithium grease around here somewhere. Thanks for the reply. Link to comment Share on other sites More sharing options...
