Hard to put into 1st Gear when cold
You are not supposed to shift into first unless you are stopped. It's very hard on the 1st gear syncro.
Wow. I never knew that, but it does make sense, and I've always found it hard to shift into first (not just on subarus) if its still moving.
If the clutch is too loose (engaging too close to the floor) it can also make it harder to get into first and reverse (when stopped).
Z
Yeah double clutching works too... And im not saying to become a ulmate racer... just an expierement for you subiebuffs... its getting cold here in az also... you can really feel the car drag more because of it... I would totaly reccomend some mobile one gl-5 gear lube... or redline synthetic... there the 2 best brands out there!!! and remember these cars wernt made for fast shifting.. especially down to 1st!!!
